Author Topic: How do you disconnect throttle cables from the grips?  (Read 653 times)
Offline Lee in Ottawa
« on: July 02, 2009, 02:16:21 PM »
Stupid question I know, but I can't figure it out. And yes i've searched.
Thanks guys
Re: How do you disconnect throttle cables from the grips?
« Reply #1 on: July 02, 2009, 03:23:54 PM »
You have the release the other end of the cables first, to gain enough slack.  One cable has a syop nut to remove.  Then you can unscrew the other from the housing.
Offline smashedmelon
« Reply #2 on: July 02, 2009, 03:37:11 PM »
Heres a thread that may help...
http://forums.sohc4.net/index.php?topic=13077.0
Which bike is it? This thread might have the shop manual that could help you...
I loosen the cables on my CB750 at the carbs, you will need to disconnect the fuel lines and take the tank off to loosen the cables before you will have enough slack at the grip end. The housing wll have three body screws, undo these and the housing pulls apart. You should be able to unhook the cables from the throttle tube assembly (at the grip) at this point, if I remember correctly.
cheers,
M
« Last Edit: July 02, 2009, 03:42:13 PM by smashedmelon »
CB750K5, CB750 K3 parts bike, CB750K3 baby-cakes
