Author Topic: On swingarm performance parts...  (Read 1040 times)
« on: May 30, 2009, 08:58:15 AM »
For those of you who are performance-enhanced (or maybe just your bikes?) and are into "all out" handling improvements...
I'm thinking of making and offering some bronze "end caps" for the swingarms. If you are familiar with these arms, the early versions of them have end caps on each end of the tube (Honda calls them a "bush") that sets the overall width of the tube and squeezes the grease felt washer inside to make a waterproof seal. (The later bikes had a one-piece flanged bushing that doesn't seal, but that's a different story: when I rebuild arms, I generally 'convert' to the earlier method for its superior waterproofing, longer life, increased stiffness, and lower cost, unless the owner has a different idea.)
These end caps are made of phenolic, which over time absorbs grease and moisture and becomes a little bit spongy. While not a huge deal for most riders, making some of SAE660 bronze instead would provide a long-wearing bearing surface that would add some stiffness in hard corners for the cafe' rider or heavy touring loads.
Setup of this arm arrangement would require a torque wrench on the big bolt, because overtorquing could lock the arm in place at first. Once the end caps are burnished in, a second retorque (loosen, then retorque) would be needed to ensure the final setup. This would probably be after about 500 miles of riding, following the initial installation. The second operation should be done with the shocks removed so the rider can "feel" when it is too tight, as if the bushing faces had not yet polished.
In other words, it's gonna be a little fussy to set up at first, but will probably only be done once in the bike's lifetime.  ::)
But, it would make a nice addition to those full-wrap or trigonometric tires on the high-speed sweepers: it will essentially be adding a 3rd and 4th bearing surface to the 2-bearing swingarm assembly: many modern sportbikes use a similar arrangement (4 bearings) to maintain the arm's alignment. The rest of the frame parts are up to this task, stock.
Please respond bck, if there's any interest? I estimate it will cost around $25 for a pair of these end caps.
Re: On swingarm performance parts...
« Reply #1 on: May 30, 2009, 09:15:37 AM »
You know I'm up for it.
I'm assuming these new parts you are considering will complement the work you just did for me, as is?
I'll be wanting to install my swingarm in the next week or two when I get my frame back from powder. Would your new parts be ready by then, or should I install with everything i have now, new phenolics etc. and just swap out parts later?
I won't actually be on the road for months, but i want to install my swingarm, so i can mock up the rest of the frame parts.
« Last Edit: May 30, 2009, 09:19:18 AM by MCRider »
« Reply #2 on: May 30, 2009, 09:50:42 AM »
MC:
These would be drop-in replacements for the end caps. You could mock up everything as-is, and they will fit right in, same dimensions. It's going to take me a week or ten days to get some bronze for it (it's special order, I guess), and a few more days to get the first parts going. I'm making a set for mine, for sure. I'd just hate to see the rest of the brass lying around, so I thought I'd offer some here.
If it gets to be a big deal, I'll probably just start making them. A local machine shop quoted me $25 apiece a year ago, so I just walked away from it back then. But, I may have enough time this summer to do something about it myself. It will take me around 2 hours to make the first pair, I imagine, but I'll get better at it as time goes by. (Wish I had a CNC lathe!)
I'm making Hondaman Special #2 in a cafe' style, so it will get the bronze for sure.
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: May 30, 2009, 09:53:36 AM »
I'd be up for a set to upgrade my existing bushes.  Mine seem to be in great shape at the moment but for $25 this sounds like a great deal.
mystic_1
- John Augustus Shedd
bradf7
« Reply #4 on: May 30, 2009, 11:17:27 AM »
I'm interested, but I wouldnt mind seeing a snap shot of it first.
