Author Topic: Ignition question-4 plugs, 2 coils  (Read 3480 times)
Offline jgary
    • Catholic Nature Cards
« on: April 18, 2005, 07:02:59 AM »
I recently replaced points, condensers, plugs, and wire end caps on a CB750 that my neighbor gave me.  Got the bike running, but I've been troubled by a question since then.  One set of points fires plugs 1&4, the other set fires 2&3.  Each coil has two plug wires coming out, so how does only one plug fire at a time, or do two plugs fire at a time?  This is causing confusion and delay.  Thanks!
John.
1972 CB 750
1976 CB 750
apr1967
Re: Ignition question-4 plugs, 2 coils
« Reply #1 on: April 18, 2005, 07:06:36 AM »
Two plugs fire at the same time.
Often called a wasted spark ignition.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: April 18, 2005, 08:15:16 AM »
It avoided the need for the complexities of a true distributer. The one plug fires on compression, the other, "wasted spark" fires on exhaust.
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: April 18, 2005, 08:47:25 AM »
That one confused me too the first time I worked on my 400F.  Another that got me was trying to set the points gap with a dwell meter.  I was having a very dificult time until I realized I had to put a piece of cardboard between one set of points to keep them from firing so I could get an accurate reading on the other set.  Once I figured it out, it was comforting to know that I could lose half the ignition system and still limp home on two cylinders.
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
« Reply #4 on: April 18, 2005, 02:22:25 PM »
Wasted spark is standard pactice on 4 cylinder bikes.
In the UK anything over 40 years old only needs insurance and Fuel.
kaysystems
« Reply #5 on: April 18, 2005, 03:36:28 PM »
Some of the electronic ignitions fire twice per rev, creating 3 wasted sparks. Surely one at the bottom of the intake stroke messes things up?
David    ???
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #6 on: April 18, 2005, 03:59:42 PM »
I know the mult. firings of elec. ignitions can't literally happen at the same time, but I always thought they occurred in "very" rapid succession to insure all fuel had been ignited??
kaysystems
« Reply #7 on: April 18, 2005, 04:18:08 PM »
My Boyer Bransden has two coils 180degrees apart & two magnets also 180 degrees apart, which means that a magnet passes each coil twice per engine revolution.
David   ???
Offline Quail "Owner of the comfortable k8"
  • Now thats good eaten!!
« Reply #8 on: April 18, 2005, 07:21:58 PM »
The field is only created when the points are closed, so when the coil passes over the 180 degree the points are open no field is created.  The cam shaft only turns 1/2 the rpms of the crank.
These wonderful little birds are great flyers, delicious eating, excellent for training your hunting dog, and just fun to shoot,or stuff and keep around the house.  Bobwhites can be put with other types of Quail and have very large penis's.  Quail are very popular with the babes.
the_genrl
« Reply #9 on: April 18, 2005, 10:40:20 PM »
pretty much explained but anyway.
  pistons 1-4 and 2-3 are in the same position, but for each matching position, say 2-3, the cam is 360 out of phase from each other (or 180 if youre lookin at the cam).  honda, being cheap, must have said "hey 360 is 360" and put only 2 spark units on the CRANK.  this way it'll fire a: when it needs to AND b: right between exhaust closed and intake open (useless).  think its called a "hit or miss ignition."       remember, if the points were on the cam, theyd need 4 points.
hey it works...look at anything that has its ignition generation on the crank and it uses the same deal (cept modern car crank position sensors)
now can you tell me how they get away with 6 lobes, 2 points, and 4 cylinders?  *hint: calc the deg between the points ;) *
Offline cben750f0
« Reply #10 on: April 19, 2005, 01:24:01 AM »
my head hurts... ???
kaysystems
« Reply #11 on: April 19, 2005, 03:44:18 AM »
But the ignittion is on the crank (1970 CB750)
David
Offline Jonesy
  • Shop Rat
« Reply #12 on: April 19, 2005, 05:07:14 AM »
I think it was Mallory that offered an aftermarket distributor ignition for the 750. This way, all the juice goes to the plug being fired, making for a stronger spark. You also didn't get the funny wear patterns in the plugs, with the center electrode on one being worn while the corresponding plug the other plug wire was attached to (say plug #3 from #2) would wear off the ground electrode, since electricity flows in a loop. So, the current would flow "down" one plug and "up" the other. There was a website that explained all this better, but I need to hunt it down...
Offline dusterdude
« Reply #13 on: April 27, 2005, 11:22:15 AM »
harley-davidson used the wasted spark technique forever it seems like.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
