Author Topic: Winter teardown, "sigh"  (Read 3850 times)
Offline Dennis
Re: Winter teardown, "sigh"
« Reply #25 on: November 08, 2005, 12:20:49 PM »
dennis,i think it may be that the charging system has to put out more amps when you are running lites than when you dont.
I was thinking that also, but when you look at the test setup, they are measuring the current into or out of the battery. Thyey are not checking the output of the alternator.
I'm still confused!   :-[
Offline dusterdude
« Reply #26 on: November 08, 2005, 12:31:22 PM »
dont worry dennis i stay confused
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #27 on: November 08, 2005, 12:47:30 PM »
There's a great response to this question somewhere from Lloyd TwoTired (I'll find it in a minute.)
The alternator output depends on revs not load.
The regulator "regulates" it so that the battery should charge at anything over tickover.
As you can see from the table, the regulator will try to maintain a battery terminal voltage of 14.5V whatever the conditions.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
