Author Topic: Winter teardown, "sigh"  (Read 4629 times)
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« on: November 07, 2005, 03:54:12 PM »
Given up on any more nice warm rides this fall :(, so brought the girl inside and am going to strip her down completely.  I want to paint the frame as well as replace any bearings that need it.  Going to tear the engine down also to hone the cycliders and install new rings rings.  Any advice, and/or tips, tricks,  on the sequence of teardown and rebuild.  And yes I will have a fridge full of beer so I can sit back and think "Damn, I'm way over my head here".
thanks
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Offline Gordon
  • 750K1, 550K2
Re: Winter teardown, "sigh"
« Reply #1 on: November 07, 2005, 04:09:33 PM »
Wait until you have all the parts you need before tearing into the engine.  The shorter the time between taking it apart and putting it back together, the easier it is.  And take lots of pictures so you can look back at them later when you've forgotten how something is supposed to look.
Online MRieck
« Reply #2 on: November 07, 2005, 04:16:19 PM »
Lay out all the new parts on a large table. Easier to locate them.
Offline clarkjh
  • Expert? If only.
« Reply #3 on: November 07, 2005, 04:54:49 PM »
one of the big things I should have done, and didn't, was measure the jugs when I put a whole topend gasket kit in early this summer.  I'm not sure on the size of rings I'm going to need once the hone is done.  But live and learn.
James
SOHC/4 #3328
Offline Uncle Ernie
« Reply #4 on: November 07, 2005, 06:36:45 PM »
A fresh marker and pen, notebook, lots of little boxes and bags. Label everything and organize everything. Map things out as you take them apart. Write down every step you take. DO NOT TRUST YOUR MEMORY!!!
Offline 78_SaltLick
  • Honda 1974 550
    • Custom Drum making
« Reply #5 on: November 07, 2005, 08:29:18 PM »
So what is "too long" of a time to let your bike sit without taking it out for a spin?? A month? 2 weeks?
Ive been taking my bike out for at least a 30 minute ride every 7 days. Thats about the only time i can find when its not raining here in portland, once every 7 days. What if i let it sit for 2 weeks, or a month before riding it again?
Gold sparkle is the place you outta be.
Offline clarkjh
  • Expert? If only.
« Reply #6 on: November 08, 2005, 05:33:16 AM »
the old girl sat for about a month, went to start her for a ride, very low battery, try the k/s and little to no resistance on the kick.  With the cold weather coming I though start the work now on the frame and do the engine after Christmas.  I'm not as young as I use to be, the bones don't take kindly to riding in the cold weather anymore.  When I was younger I use to run from the time the snow was gone till it started snowing again, would have run all year round but didn't think I could get studded tires. ;D
James
SOHC/4 #3328
Offline dusterdude
« Reply #7 on: November 08, 2005, 05:43:55 AM »
salt,i let mine sit for about 2 months over the summer and when i went to start her up she was a bit cantankerous but once i got her running she did good.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Jim Shea
« Reply #8 on: November 08, 2005, 05:57:49 AM »
Chaps,
I have no plans of any teardown or winter hibernation for my bike, I plan to ride it every time the weather permits. However, this could easily be 1+ week between rides, so is starting it every day and warming it up a good idea? or will I be doing damage to run it stationary for a few minutes each day?
Jim.
Offline dusterdude
« Reply #9 on: November 08, 2005, 06:41:51 AM »
jim,i for one dont believe its necessary to start a bike everyday,but if you do run it for at least 10-15 minutes to burn any residual moisture out of the engine oil and the exhaust
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline mick750F
« Reply #10 on: November 08, 2005, 06:44:12 AM »
Chaps,
Jim.
   Running the bike for short periods like that would surely allow a lot of condensation to build up in the crankcase and exhaust. You really need to run it 20 or preferably 30 minutes to prevent condensation build up. And that's riding, not idling. Idling for 20 or 30 minutes would allow it to overheat. Then condensation is the least of you problems. ;)
Mike
Glosta, MA
Jim Shea
« Reply #11 on: November 08, 2005, 07:15:19 AM »
I had a feeling that would be the advice. So once a week a 30 min ride should keep everythin nicely lubed up and charged up?
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #12 on: November 08, 2005, 07:18:16 AM »
I'm not sure the battery would recover fully, you might want to consider using a Battery Tender or something similar.
Jim Shea
« Reply #13 on: November 08, 2005, 07:29:40 AM »
Especially as I always ride with full beam on? I will post a topic about trickle chargers etc.
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #14 on: November 08, 2005, 07:48:01 AM »
The regulator should ensure the battery charges even with full beam on (as long as you're doing > 3000 revs (ish)
There's a charging chart on this site somewhere.
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
    • TVAM
« Reply #15 on: November 08, 2005, 07:51:05 AM »
SOHC4 Member #2393
Jim Shea
« Reply #16 on: November 08, 2005, 08:03:56 AM »
Steve,
Interesting chart, if only I could understasnd it!  ;)
Jim.
Offline dusterdude
« Reply #17 on: November 08, 2005, 08:10:25 AM »
jim,why not,its written in the queens english.  :D
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
    • TVAM
« Reply #18 on: November 08, 2005, 08:19:51 AM »
I think the 6.5 amps should be -ve meaning that if you run with lights at tickover the battery will discharge.
At all other revs it should charge.
SOHC4 Member #2393
Jim Shea
« Reply #19 on: November 08, 2005, 08:26:01 AM »
Steve,
Thanks, that makes sense.
Mark,
It's the fact that it is written in the 'Queens maths' that is the problem, I have never been very numerate!
Jim,
Offline dusterdude
« Reply #20 on: November 08, 2005, 08:54:40 AM »
i hear ya
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Dennis
« Reply #21 on: November 08, 2005, 08:57:40 AM »
Steve,
Mark,
Jim,
I don't know about this. I've always thought that I was all right with numbers and electrics. I have seen this chart previously and it always confused me. I could never understand why the nighttime charging rate is higher than the daytime rate.
Anyone want to try to explain that?
Offline dusterdude
« Reply #22 on: November 08, 2005, 09:20:38 AM »
dennis,i think it may be that the charging system has to put out more amps when you are running lites than when you dont.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Jim Shea
« Reply #23 on: November 08, 2005, 10:06:02 AM »
That was my assumption also.
Offline dusterdude
« Reply #24 on: November 08, 2005, 11:48:55 AM »
jim,im concerned,me and you are starting to think alike.if we dont stop it we may be the butt of rumor mongering.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
