Author Topic: K F and auto frames.  (Read 1282 times)
« on: June 04, 2009, 08:23:56 PM »
Anyone know the differences between the frames in respect of tank inter changeability?
Anyone have pictures of both?
Sam. ;)
Re: K F and auto frames.
« Reply #2 on: June 04, 2009, 08:30:43 PM »
oil or gas
 A model gas tank should fit all frames, none of the others will fit the A model.
« Reply #3 on: June 04, 2009, 08:54:53 PM »
Gas tank Frank. I need to know if a CR tank will fit the automatic frame.
I know that the frames are not the same under the tank as the head is removable with motor in frame in the auto.
Sam. ;)
« Reply #4 on: June 04, 2009, 09:03:11 PM »
That is where it will hit if its going to. I think on a steel tank it might be easy to mod.
 Is a CR tank aluminum or glass?
« Reply #5 on: June 04, 2009, 09:09:39 PM »
They are available in both.
Sam. ;)
« Reply #6 on: June 04, 2009, 10:54:03 PM »
CRA750?!  CR750A??
Offline eurban
« Reply #7 on: June 05, 2009, 06:39:04 PM »
I can tell you that the 77/78K tanks and the auto tanks are identical, mounts and all.  The only exception being that the auto typically had a gas gauge fitted underneath the flap cover.
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #8 on: June 05, 2009, 06:46:11 PM »
planning an automatic cafe sam?
that would be cool!
Mark Twain - Notebook, 1894
