Author Topic: 77 750 K frame quirk.  (Read 921 times)
« on: June 04, 2009, 09:00:35 PM »
Saw this today, have never ever seen or heard of this.
 1080 has a 77 K frame, that has different front top motor mounts.
Usually the right front mount above the oil filter on 750s has a removable plate, to aid in engine removal. This means there are 2 bushings  welded to holes   going thru the frame tube. The left side, on every one I remember has a welded on forging or lug with the mount hole thru it.
So I go over and look at it, and it has the welded thru frame bushings, on BOTH sides. anyone ever seen this ???
We checked 2 other 78 frames and none were like that?..
Re: 77 750 K frame quirk.
« Reply #1 on: June 05, 2009, 08:01:28 AM »
Is it an Auto frame?
« Reply #2 on: June 05, 2009, 08:09:18 AM »
Pretty sure its not, asked if the build date was on it, he said 77..I  could see the  2 lower frame tubes under the tank.
 I could see if it happened near the end of the run, like the serial # pad being moved.
 I am thinking, maybe 2 frame building lines?
