Author Topic: Dynamic timing  (Read 3750 times)
Offline Pawsoff
Dynamic timing
« on: July 12, 2008, 03:03:23 PM »
So I borrowed a friends timing light (strobe inductive style) to do the dynamic timing, I was only getting intermitant strobes from it. I checked the connections quite a few times, clamped down to provide extra pressure, tried other spark plug wires, checked to see if polarity was an issue...  All I could think of is that where this is an old timing light (a "Snap On" none the less  ;)  ) and where it is primarily made for cars... perhaps it is not sensitive enough to pick up the signal from a motorcycle?
I picked up a digital multimeter on sale this afternoon, woot $8.92 !
I will try that method and do the static timing for now, saw a neat trick where someone set it to the audible tone and when the point gap just opened... the tone went out... tighten at that setting.
Pawsoff
1977 CB550F
On the road, slowly improving the bike :)
Offline Donzon
  • CB750K4
Re: Dynamic timing
« Reply #1 on: July 12, 2008, 07:25:02 PM »
Ya, my timing light doesn't pick up well either, seems to be a common problem.  Worked better before I replaced my resistor caps!
Don
Offline fmctm1sw
Re: Dynamic timing
« Reply #2 on: July 12, 2008, 07:50:35 PM »
Mine cheapo works pretty well actually.  I noticed it will skip beats on 2/3 though.  I like the dynamic approach since it will show me if my timing is bouncing around (which it does a little).
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Pawsoff
Re: Dynamic timing
« Reply #3 on: July 12, 2008, 07:58:26 PM »
Now I know this seems like a bit of a silly question but where as I have not to date set timing what marks.... exactly need to be lined up?
To my current knowledge it goes something to the tune of:
- idle at 1050 rpms
- adjust 1-4 to the "F" mark
- idle at 2500-3000 rpms
- adjust to inbetween the lines following the 1-4 mark
- repeat procedure for 2-3
now to memory my marks look something like this
T F  1-4
When they say adjust to the "F" do they mean the second hash mark? or the actual letter "F" ?
as for the increased idle I assume they refer to the 3rd and 4th lines to go between correct?
Pawsoff
1977 CB550F
Offline fmctm1sw
Re: Dynamic timing
« Reply #4 on: July 12, 2008, 08:06:19 PM »
- idle at 1050 rpms
T F  1-4
Yeah, at idle, the letter "F" should line up on the mark.  When you rev it up, you will see two marks that are more clockwise than the "T" and "F."  I noticed that my point plate will not only rotate left and right but also will move slightly up and down (if that's clear).  Can make for a hell of a time setting it...
*edit* and I think it looks like this:
 1.4  |    |           ||
       T    F
« Last Edit: July 12, 2008, 08:09:00 PM by fmctm1sw »
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Pawsoff
Re: Dynamic timing
« Reply #5 on: July 12, 2008, 08:09:23 PM »
If the letters "T" and "F" are used then what are the two hash marks before them (counterclockwise) used for?
Also, using an entire letter for a timing mark... how accurate can that be? what part of the letter? left... middle... right?
Pawsoff
1977 CB550F
Offline fmctm1sw
Re: Dynamic timing
« Reply #6 on: July 12, 2008, 08:12:39 PM »
The little marks above the "T" and "F" line up with another mark.  Like this:
T  F
The pair of hashmarks after (or before, however you look at it) the "F" are for your timing advance.  When you rev the engine up the spark occurs earlier.  If it was Ok on 1.4, it will be ok on 2.3 ....
Watch the timing light though, my cheapo shocked the hell out of me....
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Pawsoff
Re: Dynamic timing
« Reply #7 on: July 12, 2008, 08:45:54 PM »
Thanks to one of "Freezingprocess's" previous posts I borrowed these pics to help illustrate my dilema
the marks I have look like this
So there is no Line directly above the letter "F", do I just use the line that is closest to the letter "F" (the second has mark) or do I use the actual letter "F" itself to line up with?
any help is appreciated
Pawsoff
1977 CB550F
Offline fmctm1sw
Re: Dynamic timing
« Reply #8 on: July 12, 2008, 08:51:36 PM »
Yeah, I think that looks a little different than mine but I'd wager that second line is for the "F" mark.  Use the line, not the "F."  The pair of dashes after that are for your advance (like 3000RPM +)...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Re: Dynamic timing
« Reply #9 on: July 12, 2008, 11:08:01 PM »
The printing is to label the lines.  The lines are what you use to make the alignment.
Offline Pawsoff
Re: Dynamic timing
« Reply #10 on: July 13, 2008, 07:01:35 AM »
Thanks guys, the line not being directly above the letter they corresponded to was throwing me off a bit, I figured it would be orderly but I wanted to make sure.
From my searching on this topic, if I use a multimeter (just bought one on sale) with the audible tone, I adjust it so the tone just goes off when reaching the "F" line. It looks like some people use their fingers to manually rotate the shaft for fine tuning.
Pawsoff
1977 CB550F
keener
Re: Dynamic timing
« Reply #11 on: July 13, 2008, 07:12:47 AM »
Ya that was me, m still having trouble getting it right, key OFF, kill switch to STOP and test it that way and the sound should only be off when its at the F mark and comes right back on when it leaves the F mark?
Re: Dynamic timing
« Reply #12 on: July 13, 2008, 09:08:33 AM »
Older inductive timing lights always had a hard time with the Honda coils. They are low-current coils, so as not to waste any excess electrical energy (typical Japanese engineering philosophy, here), so the spark is just enough, nothing extra. More modern lights, like the ones Sears sells now, work much better. I think my last one cost me $20.
The "F" mark should be right on the money at idle. Then rev up to 2500+ RPM; the timing should fall between the two advance marks.
If you find "jittery" timing (usually on 2-3), the shaft that holds the spark advancer on is misaligned at the crankshaft. This is easily fixed with a dial indicator: look here for instructions - http://forums.sohc4.net/index.php?topic=34455.msg355662#msg355662 .
« Last Edit: July 13, 2008, 09:11:18 AM by HondaMan »
fixahonda
Re: Dynamic timing
« Reply #13 on: July 13, 2008, 09:20:33 AM »
Wow, I have this very problem. Thanks for the off hand tip!
Offline pablo78cb550
  • mmmph.
Re: Dynamic timing
« Reply #14 on: October 07, 2008, 12:03:20 AM »
so you set the timing.
then you set the advance??
wouldn't that throw the timing off?
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha SR500 #119!
1978 Yamaha XS400
1978 Honda CB550K
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1981 Yamaha Seca 550
Re: Dynamic timing
« Reply #15 on: October 07, 2008, 10:33:46 AM »
Set the timing, then CHECK the advance.  If the advance is wrong, you have to work on the advancer.
Offline mikethejeepguy
Re: Dynamic timing
« Reply #16 on: April 29, 2009, 09:50:01 AM »
Just reading through this thread... and wanted to add this link to the resources. It includes a really handy flash animation of how timing works and how to set it.
http://oldmanhonda.com/MC/Rtiming.html
MIke
'76 Honda CB550F, Dana-S'd, Uni filtered, HID'd, LED'd, and mildly cafe'd with many plans still.
fire_strom
Re: Dynamic timing
« Reply #17 on: June 07, 2009, 09:22:26 AM »
MIke
That rocked,
 thanks
Scott
