Author Topic: Axle cap stud broke!  (Read 1017 times)
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
« on: June 10, 2009, 08:56:27 AM »
STUPID STUPID STUPID!!! So I went to torq my front wheel on & snapped one of the studs in the bottom of the fork leg that holds the cap. Can this be taken out? & if so, is it reverse or standard thread? Or  is my leg gonna have to be replaced?
jim
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
Re: Axle cap stud broke!
« Reply #1 on: June 10, 2009, 09:12:26 AM »
jim
Sure at worst a machinist can drill it out. Or you with a steady hand and a sharp bit.  THey are rt hand (regular way) threads. Righty tighty, lefty loosey. On the bike will be tough. Removal of the fork leg and soaking in acetranny (50/50 acetone/ATF) would be a start.
Good luck.
Offline JS550
  • IAFF local 1307
« Reply #2 on: June 10, 2009, 09:23:24 AM »
Theres actually enough to get ahold of. Do you think it would come out with lockjaws?
« Reply #3 on: June 10, 2009, 09:29:20 AM »
Good chance. Be nice if you could get some penetrant on /in it first.
How'd it break in the first place, IIMA?
I have an interset. I must remove mine to have the legs cryogenically treated for my project. I'm assuming a stud remover tool will work in my case. I'd hate to snap one off though.
Offline JS550
  • IAFF local 1307
« Reply #4 on: June 10, 2009, 09:35:24 AM »
Oh man. So I actually figered I would torq it, well my cheap wrench wasnt clickin & it was right at the point were i started thinking, that seems like a lot. Then snap! Do you know if the lower legs are the same on a 550?
Offline Really?
« Reply #5 on: June 10, 2009, 09:39:35 AM »
I never got mine out, still had enough threads to torque the nut but I was able to get a new stud from Honda a few months ago.
If you need a pic of it, I can get one this evening.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
« Reply #6 on: June 10, 2009, 09:40:58 AM »
At least there was an explanation and it didn't just snap.
I doubt the legs are anywhere near the same.
Offline JS550
  • IAFF local 1307
« Reply #7 on: June 10, 2009, 09:47:09 AM »
Ok, I have another set of snotty 750 forks & soaked the studs on a leg & was able to get a good stud out. Now to get the stud outta the one on the bike! Get back in a bit! And yes, Im gonna get a new, good torq wrench!
« Reply #8 on: June 10, 2009, 09:49:06 AM »
Ahh that's good news.
Offline JS550
  • IAFF local 1307
« Reply #9 on: June 10, 2009, 12:06:18 PM »
Success! Wasnt the easiest thing I've done on the bike, but its fixed. Had to pull the wheel & one fork leg out, but once that was done just had to soak the stud in WD40 then vicegrip it out.
« Reply #10 on: June 10, 2009, 12:17:49 PM »
Good news #2!
