Author Topic: toss me a bone  (Read 874 times)
gregory1975
toss me a bone
« on: June 10, 2009, 07:34:26 PM »
Would someone point me at a diagram or picture of correct routing for CB750K5 fuel lines ?
Offline Colonel
  • 750K5
Re: toss me a bone
« Reply #1 on: June 10, 2009, 07:49:15 PM »
Do not know if this is the way they were routed back in 75 but on my bike the fuel line passes through the hole in the carburetor plate then to the 'T' connector.
gregory1975
Re: toss me a bone
« Reply #2 on: June 10, 2009, 07:59:58 PM »
Since my petcock has only one outlet where does the line coming off that split?  There are two holes in the carb assembly plate too.  So does a single piece of line run through each of these into the the tees in the carbs ( between 1&2 and between 3&4)?
Offline Colonel
  • 750K5
Re: toss me a bone
« Reply #3 on: June 10, 2009, 08:11:03 PM »
See the picture attached...
I took the pic as I was removing my carbs so do not take the position of the fuel line - twisted downward - for the actual setup.
The main fuel line - from tank - passes throught the assembly plate hole, then connects to a 'T' junction from which to separate lines split to the carburetors.
Hope this helps.
« Last Edit: June 10, 2009, 08:15:36 PM by Colonel »
gregory1975
Re: toss me a bone
« Reply #4 on: June 10, 2009, 08:14:34 PM »
Thanks!  That does help.
