The early seals were the short ones, later (341) were taller. But if they are aftermarket seals they often come short with a washer.
AS mentioned, you can do without. If they are OEM, someone bot the old seals, which will work in any fork. If one buys the tall seal, it will only work in a later leg.
The taller seals had a third lip to make them seal better.
