Your just getting started on the spending part... you don't know how Mo will run yet. How Mo will ride. Whether Mo will need better brakes, suspension or what have you.
Don't I know it. I'm praying the PO knew what he was talking about and she'll run ok, but only time will tell. Like I said, I did this all backwards. Worst case scenario, I'll have a great looking non-runner
I did mine over a winter.(and then a little)
Not as easy working in a garage with no heat, and painting is pretty much out of the Q....
But I got what I could get powdercoated(for free) at my last job, so it evened out not being able to paint the tank or side covers.
Winter rebuilding of my bike killed the riding fever pretty well.
Winter is my fa. time to mod things.
Yeah, when I buy my own place I plan installing some sort of heater so I can do as much of this crap in the off season as possible. Should also help with the cabin fever.
So I cleaned out the new spray gun I bought (the cup seemed pretty dirty for some reason), shot the second round of clear on the front fender. AND THERE WERE FISHEYES!! Seriously, what gives. I emptied the compressors and water trap out, installed a desiccant snake in the one line that I'll be using solely for the spray gun, and even put in secondary desiccant filters on the guns themselves! So I'm as sure it isn't the air as I can be, given I'm not sure how I'd test it. This leads me to think there are only a few other real possiblities.
1. Even after a good wet sanding, whatever caused them in the first place was still present.
2. I didn't get all the packing oil/grease out of the gun before I used it. I sprayed laquer thinner through it, and removed and wiped down everything, so this seems a little unlikely. Still, I took the cup in after this and washed it with soapy water just to be sure.
3. There is something wrong with the paint itself... I'm thinking this is unlikely as I have not had any problems with this quart of clear prior to spraying my gas tank. It just occured to me, the catalyst I am using was first used on the gas tank, hmmm I wonder if this could be part of the issue.
4. There is something in the ambient air that is getting on the part. Since I use wax grease remover before I coat and use a silicon free tack cloth, this doesn't seem as likely.
At this point I'm thinking to eliminate 1 I'll spray the tank next and see if I get fish eyes. If that is the case, it doesn't entirely rule 1 out as a contributing factor, but makes all the others very possible. I'm also going to order some fisheye eliminator and see if that will help with the front fender. What a fun learning process
Oh well, I'm still stoked enough about the carbs and saddle bags that this isn't getting me too down.
Brandon
