Dear Motorcycle Gods,
I am running out of oompf!!
It is getting warm around here, and that always saps my energy and drive. Plus, I'm experimenting with the multi-part paint I bought, namely the primer and it hasn't gone so well. I was getting orange peel really bad, so I called the place I bought the paint and gun kit from and they said I was using too small of a tip. I hope thats really what it is, if not guess I'll go from there.
On a lighter note, finally got the fundage to pick up the parts bike, so I will be doing that tomorrow, and then see if I can set some sort of record for tearing it down in just a day. I've decided to keep the buggered frame and make it into a bobber. I am takeing a metal sculpting class either fall or spring semester ( I really hope it means welding, because if the instructor gives me a lump of lead and a file and tells me to get sculpting, it won't go so well.) They usually have you do a project, and so for my project I'm gonna weld a hard tail on the frame and weld a new steering stem onto the front. At least that is the current thinking, and my awesome wife said she is fine with it!
As for this build, I made myself a new tool. I remember when I redid the steering stem bearings on the CB500 I just sold that I swore if I ever did any more I would make something so I didn't have to use a pin wrench or even worse a punch and hammer to remove that weird little cap. I cut a 33mm socket to fit the notches using my dremel, a cutoff wheel and a really cool cutting bit I have. It's not the greatest looking thing, but it will hopefully do the job. On the current frame the cap wasn't even finger tight (that actually scares me a bit.)
I decided to try and straighten out the rear fender that came with my bike instead of using the one off of the parts bike. The one on the parts bike looks really good and straight and mine had some creases in it. Since I plan on painting my fenders anyhow, I have no problems using a bit of body filler, so I hammered my fender out as well as I could using a hammer and dolli set I purchased at Harbor Freight. I doubt I'll ever win any awards for my body work prowess, but I straightened out the lines pretty well, and it will need just a small touch of body filler. I also cleaned off the bottom side and sprayed it with some 3M undercarrage stuff. This will hopefully keep it from rusting out on the bottom. I don't have any pictures of the fender before I started hammering on it (sorry) but I will get some close ups of the hammered area, and then the after shot.
I'm now working on cleaning the underside of the front fender, and it only needs some very very minor tweaking to get it to look good. Hopefully I can take the little I learned on the rear and do a good job with the front.
I also have pics of the positive pressure mask I made using an old Australian gas mask (yes Hush, I had to remove the sheep), some PVC fittings, and air hose. All told it cost me around $60 or $70 dollars to make. When I first dreamed up this adventure I thought I would be using paints that have Isocyanates in them, so I started looking at the fresh air systems as everything I had read said they were the only way to go when using that kind of paint. Since I couldn't afford the $500+ for the commercial ones, I made my own and it works really pretty well. The constantly flowing air keeps the visor from fogging up and keeps my face cool which is nice. There is a tear away plastic sheet on it so when it gets too dirt I can just replace the sheet.
And now the pic of my spray booth. I tend to go way overboard on things and this booth is something of a shrine to that I suppose. I have a box fan on the inlet side pushing air in through some paint booth filters I bought off eBay. The fan is on the inlet side so the fumes don't exhaust past it and go BOOM!! I'd read that was a danger, so I figured out a way around it. I have lights on all four sides, and normally a few on top, but the ones on top are on my sandblasting booth for the moment being. There is a paint booth filter on the exhaust side which does a really good job of removing the over spray from the air before it goes out. This is a bonus as my moms car is usually just outside the garage, I doubt she would appreciate the free repaint
Brandon
