First off, you only need a tap, just get a new bolt.
Didya kick the "mechanic" in the nutz yet , that "helped" you out
![Huh ???](http://forums.sohc4.net/Smileys/default/huh.gif)
If you have a calculator, divide 1000 by 28.. should be in the neighbor hood of 36 or so.. then divide that by .03937.. that will give you the metric pitch.
Soon someone will come up with proper measurement. OIff the top of my headI am thinking it is a 16mm thread or so.
KBC has a large quantity of odd pitch taps in metric, probably under 100 bux, probably your cheapest out.
make sure you grease the tap, and dont send any buddies to the "mechanic"
