SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
CB750A - Hondamatic
(Moderators:
Sam Green Racing
raymond10078
Topic:
CB750a Carb question
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: CB750a Carb question (Read 3225 times)
Hambone
Guest
on:
June 15, 2009, 04:51:27 PM »
I'm getting ready to rebuild my 1977 CB750a carbs and had a couple of questions. I think the standard carbs on the f and k models are 28mm and the a are 24mm. Has anyone with an a model added pod air filters? Since the center bore is different can I assume the pod is also? The bike has a pipe on it, if I add the pods any idea on what I should do as far as jetting?
Logged
Hambone
Guest
Re: CB750a Carb question
Reply #1 on:
June 16, 2009, 12:57:01 PM »
Anyone have any ideas?
Logged
Inkscars
grumpiness comparable to an
Old Timer
I have a box. I'm used to being ignored.
Reply #2 on:
June 16, 2009, 01:10:21 PM »
Yours is a hondamatic?
Does it have PD carbs on it or the old style?
Logged
81 Hardly Davisson
Spanner 1
Old Timer
CB 750 K0 ( always thought it was a K1!) + CB750K8
Reply #3 on:
June 16, 2009, 01:49:20 PM »
Yep, you have 24mm PD type carbs....pods to fit would be smaller diameter than K or F pods ( 28mm ). Stock main jets are 102's on your bike, with 4into1 exhaust and pods, I'd try 105 or 110 main jets......trial and error really.......
Logged
Hambone
Guest
Reply #4 on:
June 16, 2009, 03:31:54 PM »
Spanner, Thanks so much. Is there a place on my carbs I can measure, so I can order pods that fit? i.e. does the pod need to have a 24mm opening or is that the venturi opening on the carb?
Logged
Spanner 1
Old Timer
Reply #5 on:
June 16, 2009, 05:58:30 PM »
As far as I know they would just be 24mm pods, i.e. they are sized to fit 24mm venturi.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
CB750A - Hondamatic
(Moderators:
Sam Green Racing
raymond10078
Topic:
