Author Topic: Why are the carbs and airbox so freaking hard to get off and back on the bike???  (Read 7163 times)
MrHellpop
I cannot believe what a challenge it is to get the carbs off and then back onto my 77 750k!!!! It is by far the most difficult thing I have had to deal with on the bike! I'm not really asking for suggestions, just venting!  :)
I've taken them off and got them on again previously, but this time it's even more of a pain in the ass! I've now wrestled with getting them back on for about an hour in a standard Texas night where my garage is about 95 degrees F... Sweat everywhere, running in my eyes, glasses falling off my face trying to make those little boots get on the intake throats of the carbs. aaaargh! I even thought it'd be easier this time because I am using a little L shaped tool to try to slip them onto the carbs. No luck yet! Two of the clamps were smooshed while I was jamming the carbs into the frame. I figure I'll straighten em out and re curve them once the boots are on the throats. Of course the two in the middle are pretty much impossible to get on, but the outside ones are less of a challenge. It's enough to make me want to get pods just to avoid dealing with that damn airbox!
 :o
Offline Hush
Yeah we feel your pain brother. :D
I've found that tapping the carbs forward using a block of wood on the shoulders and a hammer makes em go on easy enough, the airfilter boots are a pain to line up but at least they are softer.
Beer helps, that and time away from the dreaded carbs, go buy more beer and by then you will have stopped sweating and will be ready to try again. :)
Online Alan F.
I know just what you mean.
I recommend tying a rag around your head to catch the beads of sweat before they get into your eyes/glasses, those 'rags-in-a-box' paper towel type rags work great just tear off three, roll them up and tie them on.  They'll keep your face dry and when they get damp they'll help keep your head cooler
Offline Johnny5
    • CB350F build thread
The last time I had to put the carbs on, I used a cheap little $9 heat gun from Harbor Freight and warmed up the rubber boots. The carbs seriously went on in less than a minute. In the past, it took easily a half an hour, 50 curses, and a couple bloody knuckles to get them on.
The best $9 I ever spent.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline Jonesy
  • Shop Rat
I don't drink when working on anything mechanical anymore. You get to bound and determined to accomplish whatever you're doing that you don't stop to think of the consequences.. often breaking something in the process (don't ask me how I know...).
New carb and airbox boots will work wonders for carb installation and removal. They are still available from Honda and are cheap insurance.
Offline rhinoracer
A little searching before installing the carbs would have helped.
In my case a 2x4 against the carbs, a ratchet strap to pull forward the 2x4 against the frame downtubes. No blood, no sweat, no beer.
Baja native.
Offline medic09
+1  !
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline Laminar
  • Retsam
Just get pods.
Oh no, look out!
« Last Edit: June 18, 2009, 07:34:22 AM by Laminar »
Offline crazypj
  • I'm brill, me
750 is the easiest one to do.
Just put top part of airbox on first, assemble lower section after its fitted correctly (and be glad you don't have a 350/400f)
PJ
Offline Gordon
  • 750K1, 550K2
New boots!  New boots!  New boots!
It's just that easy... ;D
I smeared a little lube like armor all on the lips of the boots. Any rubber preservative should work. Tire changing lube.
Also, 2x4 lever, never tried the ratchet straps but heard they work well.
On all 750s I work on, I spray the boots inside with silicone as soon as I remove the carbs, then spray again just before installation. And, if it is more than a day in between, I spray once or twice more on the whole boot(s) so it can soak in an liven up the old rubber a little. I still have the original boots from 1971, and the carbs come off with a twist and go on with a pop and that (2x4 + leverage) mentioned above, in 5 minutes or less.  ;)
BTW: someone here talked about using wintergreen to soak these boots and bring them back to life: anyone know where can you get that stuff?
Online Alan F.
I think you can find it at most natural foods type stores, maybe pharmacies, or probably your best bet might be aromatherapy type shops.
http://yp.yahoo.com/ypResults.py?stp=y&stx=96296287&city=Lakewood&state=CO&uzip=80226&msa=2080&slt=39.7038&sln=-105.081268&cs=4&qtx=aromatherapy
I remember reading that some time ago. I think someone was adding Wintergreen to an existing product like Rubber Renu thinking it would help. Many thought it was unnecessary and did not improve the product.
Makes it smell better?   :D
Offline tlbranth
I just ordered new manifold boots from David Silver and was a bit disappointed to find that they are pretty stiff. Not much better than my 39 year-old ones. But I can tell you how to get the carb assembly and the airbox on pretty easily. Squirt some Armorall on a paper towel and wipe it around the inside of the rubbers to be assaulted. Straddle the bike, position the part/assembly and push while arcing it up and down. It'll go right on.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Johnie
I also use a little lube and a 2x4 for some leverage and they popped back on.  I have had them off and on a few times and having that lube on there helps them to come off much easier too.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Laminar
  • Retsam
Sounds like a fun night.
Offline Gordon
  • 750K1, 550K2
I'd steer clear of the Armorall when dealing with the carb boots.  Silicone lubricant is probably best and won't degrade the rubber.
Offline tomkimberly
PJ
350F's are easy....
Tom
Offline coldright
  • That's Ms.
  • to you
I like the heat gun idea, softer would help those damn things alright.  I had to chuckle after reading this thread.  A friend helped me get the carbs off my 750 this past Sunday... After much struggling, cussin', and sweating, they finally came off - after the airbox, of course.  At one point there were three of us manhandling the bike.  My friend wasn't feeling well before we went into this misadventure and afterwards he said he felt like he wanted to throw up.
Glad to know the new boots aren't any softer... I was thinking about ordering a new set due to this whole thing.  Do you remember what they cost?
Offline Inkscars
  • grumpiness comparable to an
Oh honey. I can get mine off, disassembled, swap jets, move needles and back together and on in a little less than an hour.
You can do it. Take a step back. Take a look at it.
The 77s like to try your patience. don't let it win!!!!!!
If you  need something, pm me, I may be able to help!
81 Hardly Davisson
Offline Dave-and-his-550
  • I know the pieces fit...
You guys are referring to the intake boots? Or the airbox rubbers?
I'm not sure how different the 550 is, but when I take off my carbs, I first pull off each airbox rubber, then with a strap (Kind of like pictured above) I pull back the airbox as much as possible. Completely loosen and pull the intake clamps away from the carbs, and they pull right out. Then it takes just a little bit of moving back and forth, up and down and the carbs slide out.
I was surprised how easy it was!
Offline Inkscars
I leave the intake side boots on the carb bank. Too easy to get them spun a little out of whack.
I use P.T.F.E to smooth the reinstall process.
81 Hardly Davisson
Offline brianzenk
  • I love Hondas
    • Crazy ART stuff - BEWARE
After taking apart the carbs a few times on the cb550 1976.
I would pop the boots into the airbox install the carbs
then pull the boots thru the air box from the inside
starting with the inside boots first and work outwards.
'Oh #$%*!' is usually the moment when your plan parts ways with reality !
Offline Johnny5
Seriously, before I was using the heat gun method, I swear I was rocking the carbs back and forth so hard, I had to steady the bike from tipping over. Even with my brother's help, it was a complete pain.
Heat. Gun.
1971 CB350
1973 CB350F
