Author Topic: CB750 front sprocket/ output shaft.  (Read 2008 times)
robrffr
« on: June 18, 2009, 10:54:59 AM »
On the engine we've put in to my mates CB750, instead of the usual fixture arrangement, ie retainer held on to sprocket by two small 10mm bolts, this one has a bolt in the middle of the shaft, and th sprocket is different, it's a e331T15. The old engine used a E228T18. But no of the manuals me mate has shows that type of fitting!! Any ideas?
Offline Johnny5
    • CB350F build thread
Re: CB750 front sprocket/ output shaft.
« Reply #1 on: June 18, 2009, 11:09:44 AM »
My CB750 only has one bolt securing the front sprocket.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline scondon
  • Mmmm......tasty bugs
« Reply #2 on: June 18, 2009, 11:26:35 AM »
"e331T15" - Am guessing from this # that the sprocket is a 15 tooth/ 630 which is standard on the 77-78 750k engines, like johnny5 has. You should be able to use a 18T/530 sprocket with little fuss. I use them on my '78 750, single bolt holds them on.
Offline Johnny5
« Reply #3 on: June 18, 2009, 11:36:00 AM »
Yeah, my 750K7 had originally the 15t front which I converted to a 530 chain and 17t front 48t rear.
1971 CB350
1973 CB350F
Offline Old Scrambler
« Reply #4 on: June 18, 2009, 11:42:37 AM »
Now that you have a K7 or K8 motor in an older frame.......note that the rear wheel/sprocket will be off-line by 10mm.  The later models have a longer (wider) countershaft sprocket mount for larger chain and bigger tires on the rear.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline mrosso
  • The before picture.
« Reply #5 on: July 24, 2009, 07:51:32 PM »
Looks like I'm in the save F**** boat. I just found out I have a '77 CB750 K7 motor and a '71 K frame. Is there any way to get this combo to work? Can you swap the rear sprocket on the '71 hub for a '77 sprocket?
« Reply #6 on: July 24, 2009, 09:51:32 PM »
Just swap the rear sprocket carrier, or shim out your sprocket, if you have enough bolt.
