You could lay the frame and motor on the right side and take the frame off the motor.
I was trying to avoid that. I built a lift to pull the engine up and help mount it on the engine stand, but it isn't long enough to reach the ground.
It will take you about 15 minutes to pull the top end off and if your going to work on the motor anyways i really don't see what your reservations are about removing it now? plus it will make taking the motor out way easier.
Maybe I'm just being anal (I'm that way sometimes
) but I really just wanted to take it out as one unit, mount it to the engine holder, cover it with a tarp and get all the painting and body work done before I tear into the engine. I'm trying to do one set of things at a time in an effort not to have everything strung out from here to BFE, although I'm not doing such a great job.
Also, with that one engine mount on the front of the bike being welded there (I swear it is!) it can't be lifted as it hits on the lower case. If the engine mount is supposed to come off and one of the lower frame rails as well, I'd rather go that route. This bike was laid down on that side a while back, didn't appear to be anything major, no frame damage that I can see, but they must have welded the piece back on there or something. Darn PO's.
Brandon
