Author Topic: very custom build  (Read 1244 times)
Offline MJL
  • Don't listen to me, I'm no
very custom build
« on: June 22, 2009, 07:06:20 AM »
Ok, I have a Subaru EA82 motor on my floor, and potentially a Yamaha frame.  Yes, I want to combine them.  ;D  The motor is 187.4 lbs dry, ~100 hp, ~100 ft-lbs. Yes, I will need a radiator, but the big thing is a 90* gearbox so I keep the chain drive.  Any thoughts or ideas?
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: very custom build
« Reply #1 on: June 22, 2009, 08:01:48 AM »
Um... it's like 4 feet wide....
You wouldn't be able to lean the bike more than 20 degrees without scraping the heads, unless you put the engine up so high that center of gravity would make the bike almost unridable at anything other than 100mph.....
I'm just sayin....
No.
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #2 on: June 22, 2009, 09:05:48 AM »
Chain drive will be hard to retain.
I'd ask around to local machine shops and see if they'd be willing to mate a BMW trans to the back of your engine.
Either that or you can take an old HD 4 speed gear box and have someone make a 90 bevel drive and a custom back cover to get your sprocket out there.
Looks like you have TONS of fab coming your way.
The engine will be hard to mount but it could be done. You'll just have to give up handling like a normal streetbike. Think chopper but extremely short.
Oh I had an idea.... find a front wheel drive transmission and use that (one side only) for your sprocket final shaft. Or you could use both and have dual chains.
Might look silly but would be pretty interesting at shows.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
« Reply #3 on: June 22, 2009, 10:03:46 AM »
Might be cheap to cut a Goldwing tranny & drive, worth a look.
 or mount like a 750 engne and jackshaft (with covers) to a H-D 4 or 5 spd.... just some possibilities.
 ..I think 90 deg drives are easy to find, but one that will handle the HP & speed will be spendy....
Offline KB02
« Reply #4 on: June 23, 2009, 05:01:15 AM »
Need pics...
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
