Author Topic: 5.5" wheel fit w/ 78 750 swingarm or 81+ dohc swingarm ??  (Read 694 times)
Offline acteg
« on: June 22, 2009, 07:10:39 AM »
I have this crazy idea of putting harley fatboy rims on my 550 project bike.  I'm currently building a carbon fiber tank / cafe seat, I've shaved off all the tabs and deleted uneeded portions of the frame, and I am fitting a modern sportbike front end on the bike.  A local guy has a set (front and rear) for $150 and I am toying with the idea of picking them up and seeing if they will work.
some questions?
Is this a stupid idea?
Does anyone know if a 5.5" x 16" rim will clear a 78 750 swingarm or a 81+ dohc swingarm?
If it does clear will I be able to get an offset sprocket to work or will it be too offset to bring into spec?
Offline Toxic
Re: 5.5" wheel fit w/ 78 750 swingarm or 81+ dohc swingarm ??
« Reply #1 on: June 22, 2009, 07:51:14 AM »
since you asked, Yes it's a stupid idea, but it's your bike and it's about individuality so go for it.
I believe the folks to ask are on the chopper boards.
Google Honda Chopper forum.
Offline acteg
« Reply #2 on: June 22, 2009, 09:56:32 AM »
forgot to mention the rear would be a 160 tire (wheels come with brand new tires).  I know tire clearance wise a 150 will fit with a 78 750 swingarm, just not sure about sprocket / offset.  I'm thinking about just buying the wheels/tires and giving it a go since they are pretty cheap.
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #3 on: June 22, 2009, 10:59:03 AM »
It can be done, but expect on the short side to have to widen your swingarm.
Best to be prepared for the worst.
Either that or you could always do a swingarm swap. Or hard tail.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
