Completed my checklist:
Carbs rebuilt - did get a piss out the overflow but it stopped
Gone thru all electrical connections
New starter brushes but starter still doesn't work
Filled the 27 yo tires with air
Chain slack set at 3/4"
Changed the fork oil
New NGK's gapped at .025
1/4" cut from the ends of plug wires and ends reattached
Valves done - exhaust were good, 2 intakes were a little loose
400 grit paper pulled thru points - I'll put new ones in later (I have 'em)
New fuel lines - got the routing right the 2nd time
New bulb needed on rear tail light
Dropped pan, cleaned oil screen
Oil and filter change
New battery (of course)
Probably some other stuff I can't think of right now.
With 27 yo tires, no front brake (caliper off -still need to rebuild), and a 27 yo license plate I couldn't go too far or ride too fast. I didn't get out of 2nd gear and didn't go over 4K revs - BUT MAN, DID I HAVE FUN RIDING AROUND THE BLOCK.
