Author Topic: newbie question: cylinders 3 & 4 not firing  (Read 1119 times)
Offline jwaych550
« on: June 24, 2009, 06:06:25 PM »
Hi all,
My friend d3buttz and I are working to get my 1976 CB550 super sport four up and running but I have run into a road block with timing issues.
Cylinders 3 and 4 are not firing. I have spark and fuel... Any suggestions?
Thanks a lot,
jwaychoff
Offline d3buttz
  • More than just an
Re: newbie question: cylinders 3 & 4 not firing
« Reply #1 on: June 24, 2009, 06:13:43 PM »
your bike sucks :P thats why.
just kidding, we have it starting and running, on 1&2, and i know that the carbs are straight, my guess is its timing..........but timing is by 1&4 and 2&3 and thats where im lost. we also replaced the condenser.
« Last Edit: June 24, 2009, 06:16:29 PM by d3buttz »
http://forums.sohc4.net/index.php?topic=80508.0
1975 cb750f
1975 cb550k
1972 cb350k
1974 tl125
1996 Nissan pathfinder
1972 Datsun 240z
2002 Nissan sentra se-r spec-v
Offline Spanner 1
« Reply #2 on: June 24, 2009, 08:24:31 PM »
Are ya for sure the plug wires are on the right plugs? Good clean plugs?
Float bowls full on carb 3+4  and the idle/slow jets clean?
Offline 750goes
  • it will live
« Reply #3 on: June 24, 2009, 08:30:48 PM »
Coil 1 fires 1 & 4
Coil 2 firse 2 & 3
as seen from sitting on the bike coil 1 on LEFT coil2 on RIGHT
check spark at lead ends against head or other object, take off the plug caps and measure resistance,
all the same sort of plugs ??
All the same resistance caps ??
all plug leads good ??
Good battery voltage ??
plugs new or old?
Offline jwaych550
« Reply #4 on: June 24, 2009, 09:56:36 PM »
Thank you,
Coil leads are correct order. Brand new battery. Plugs spark... will re-check the plugs. Although plug wires are a different make on 3 & 4. Will check back after inspection from previous owners work.
Offline OakBehringer
« Reply #5 on: June 24, 2009, 11:50:20 PM »
You have spark... are you sure you have fuel and compression? Are the plugs wet with gas after running it when they're not firing?
1974 350 Four - SOLD
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline oldbiker
  • I HATE RAIN
« Reply #6 on: June 24, 2009, 11:55:16 PM »
Are you sure that plug leads 3 & 4 have NOT been switched? Remember that one coil feeds no's 1 & 4 and the other coil feeds 2 & 3.  If 3 & 4 have been interchanged, this will cause 3 & 4 to not fire.
Offline tomsweb1
  • '78 CB750A
  • '78 CB750A
« Reply #7 on: June 25, 2009, 05:43:04 AM »
I had a situation where # 2 and 4 were not firing. It was extremely strange, when the plug was gounded agains the case, there was no spark, but as you pulled it away, massive blue arc across the electrode, and to the case.
The problem turned out to be that I had used resistor plugs (dr8esl, what the canadian bikes use) and resistor caps ( what the american bikes use, in conjuction with non- resistor plugs) I put d8eas in, and she purred like a dream.
Have you already tried checking the resistance on the caps and plugs? one or the other of each should have a resistance of 5,000 ohms. If your spark plug caps haven't been replaced, you may want to do that anyway, it's a relatively inexpensive insurance plan, if you will.
Hope this helps!
Present: 1978 CB750A, 1978 CB400A, 1983 Nighthawk 550, 1984 CM250C
Past: 1977 XL100, 1982 KZ1300
« Reply #8 on: June 25, 2009, 06:11:47 AM »
Where do you live, Jway? I'm in Lakewood...
Offline jwaych550
« Reply #9 on: June 25, 2009, 07:57:34 AM »
Cool thanks alot. There are a lot of suggestions here that I need check and or re-check. Thanks for the advice.
Hondaman: I live on 48th and Lowell (right by Interstate 70).
