Author Topic: Project bobber build 70' cb750 four  (Read 28375 times)
Offline Reindeer
Re: Project bobber build 70' cb750 four
« Reply #25 on: August 23, 2009, 10:20:59 PM »
I like where this is going...
75 CB750 hardtail bobber
78 CB750 project...might run someday
Offline kerryb
  • Not a very
« Reply #26 on: September 01, 2009, 04:03:39 AM »
I too, like where this is going.  Is your hardtail going to include stretching the wheelbase?  How will you keep/check alignment during welding?
Offline 750four
  • Bomb's away!!!
« Reply #27 on: September 01, 2009, 12:28:57 PM »
I'll leave to swing arm in. I've made some plates that I can actually bolt on the drop outs and the new axle plates. From there it's cutting and bending tubing. Also being level and taking quite a few measurements is required. After the rear is built, I'll unbolt and cut away the rest.
Also got in my velocity stacks. Thinking of leaving to tank and fender raw steel and painting a big red Japanese sun on the side of the tank. To much?
« Last Edit: September 01, 2009, 12:31:17 PM by 750four »
Offline rustrocket92
  • Mad Fabricator
  • Buster is in the Lab!
« Reply #28 on: September 02, 2009, 08:09:14 AM »
I like what you have so far man !
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Offline bmikkalson
« Reply #29 on: September 02, 2009, 01:53:37 PM »
What size and where you get the tires?
Offline valt
« Reply #30 on: September 02, 2009, 02:51:32 PM »
You can get them from coker they are firestones.
http://store.coker.com/450-18-firestone-deluxe-champion-blackwall-tire.html
I have a set on my bike, and I believe greenjeans has the same set.
Offline DaytonGuy
« Reply #31 on: September 06, 2009, 04:41:14 PM »
Where and how did you mount the rear fender.
Looks good!
Offline 750four
  • Bomb's away!!!
« Reply #32 on: September 08, 2009, 08:13:19 PM »
fenders not mounted, everythings just mocked up. Coker deluxe chapions front 19 x 4.0 and rear 18 x 4.50. I"m picking up the tubing tomorrow and should have the rear axle drops cut by the end of the week. Hopefully if I every get some spare time this will be hardtailed real soon.
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #33 on: September 09, 2009, 09:53:41 AM »
I love those tires too.  But that link says they require tubes...  Is that true?  I haven't seen a tire that used tubes in a long time (granted I don't work in a tire store...).
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
Offline 750four
  • Bomb's away!!!
« Reply #34 on: September 12, 2009, 06:55:49 AM »
Yep, tubes and rim strips.
Offline valt
« Reply #35 on: September 13, 2009, 01:30:56 PM »
Yeah pretty much any rim that is spoked is going to require a tube. There are some special spoked rims that are designed to not use a tube, but not on the old hondas. You can use a tubeless tire on a spoked rim but you will still have to run a tube.
Offline kerryb
  • Not a very
« Reply #36 on: September 15, 2009, 08:41:46 PM »
I did what you said; cut, bend, measure, cut, bend, measure, bend, measure, measure, ponder, ponder...  What do you think I should do with these last two tubes.  How do you plan to treat these in your hardtail?
Offline Zaipai
    • My Home page
« Reply #37 on: September 15, 2009, 08:44:13 PM »
Looking good so far, looking forward to the final pics of the completed bike.
Its my Avatar..
75 CB550F  |
stealthy
« Reply #38 on: September 17, 2009, 01:00:07 AM »
great looking bike!
« Reply #39 on: September 17, 2009, 01:24:13 AM »
I would cut these down tubes to fit the back of the frame and bend them in and weld, i know its not that easy but thats what i would be looking to do, just like the under tank frame rails.
Offline kerryb
  • Not a very
« Reply #40 on: September 17, 2009, 02:13:04 PM »
Oh dear!  I have to apologize to 740four for rudely putting a picture of my bike on his project thread.  I have been watching his progress with great interest.  He was part of my inspiration for getting this far.  I have no tank or seat yet, just vague ideas.  I'll start my own thread when I build up the confidence.  Until then, thanks for the support and lets see see the great bike 750four is building.
750four, please accept my apologies...kerryb
Offline 750four
  • Bomb's away!!!
« Reply #41 on: September 20, 2009, 06:38:50 PM »
no worries, you're ahead of me as far as the build is concerned. Your's is shaping up real nice too.  Good luck keep us posted.
Offline 750four
  • Bomb's away!!!
« Reply #42 on: April 08, 2010, 08:00:45 PM »
frames done. Seats made/mounted,  located the new tank mounts today. Next are the new head light bracket, kick stand and rear brake lever mount.
After the neck was cut:
« Last Edit: April 08, 2010, 08:02:28 PM by 750four »
Offline Zaipai
    • My Home page
« Reply #43 on: April 08, 2010, 08:15:25 PM »
Very well done.. Looks great so far!!
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline 750four
  • Bomb's away!!!
« Reply #44 on: April 18, 2010, 06:05:14 PM »
ready to go home and start the build to be torn down again.....
Offline Zaipai
    • My Home page
« Reply #45 on: April 18, 2010, 06:13:51 PM »
Wow, looking great so far.. Keep em coming as you progress!!!
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline 750four
  • Bomb's away!!!
« Reply #46 on: April 21, 2010, 07:25:00 PM »
Primed, painted, half way assembled....Forgot the head has a broken off exhaust stud :-\
Here are a few better pics. Made my headlight mount, seat, and seat bracket. Oh ya, my frame too... ;D
Offline Zaipai
    • My Home page
« Reply #47 on: April 21, 2010, 07:29:18 PM »
Wow that looks fantastic, can't wait to see the motor in it.. Excellent work on the headlight mount..
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline 750four
  • Bomb's away!!!
« Reply #48 on: April 30, 2010, 05:23:30 PM »
covers schmoothers....
Working on the head now. Ideas behind strengthening the cam tower bolts. Other than helicoils. Also Cycle x Dual carb, hi performance valve springs, heavy cam chain, and en-695 (.370/282) cam on a stock bottom end? Looking to ride this summer and than build the bottom end next winter(budget). Thoughts?? Maybe a way to get away with it without just rinsing the cyclinders with gas all day? Different plugs?
Offline Zaipai
    • My Home page
« Reply #49 on: April 30, 2010, 08:06:11 PM »
Nice job on the covers..
.: Scott :.
Its my Avatar..
75 CB550F  |
