Author Topic: 110/80/18 dunlops front and back of 400/4?  (Read 1108 times)
400rat
« on: June 30, 2009, 07:35:58 AM »
is there really a good technical reason to not do this if they fit?...a friend is giving me a brand new set and i am broke...i dont plan on cruising the canyons too much...i dont care about the balloon look too much...just want to know. thanks:)
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: 110/80/18 dunlops front and back of 400/4?
« Reply #1 on: June 30, 2009, 07:39:32 AM »
Do you have a fender?
100's rub a bit on the 350f front end. I think the 400f is about the same? I really don't think a 110 will fit.
Also, handling will suck with equal size tires, especially that large, on the bike. Are they both front or back tires? That could also cause a problem.
No.
« Reply #2 on: June 30, 2009, 07:47:03 AM »
I have a 110 on the rear and a 100 front. Take em both, use one on the rear and the second for next time.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #3 on: June 30, 2009, 08:48:08 AM »
I doubt the 110 will fit in the front, and i don't think running a front tire in the rear is good. Only a few models of tires are deigned for both front and rear use. Otherwise, their construction (and tread pattern/direction) is different, and should not be used on the wrong end.
120 is huge for a 400 rear, but it might fit.
No.
Offline gregk
« Reply #4 on: June 30, 2009, 12:23:54 PM »
The 110 will rub on the fender brace on the front.  I have a 100 series tire on the front of my 400 and had to 'tweek" the fender brace so it wouldn't rub.
the 110 will work on the back though.
greg
I don't want it to go like a motorcycle, I want it to go like a rocket!
