Buy the best welder you can, but as yourself how much of a welder you need.
A 220V machine will certainly do everything you want, but how often will you be welding anything thicker than 1/4 inch? Most things on a motorcycle are far thinner than that, so 110v is fine for this application. Also, unless you have a 220v line in your workspace you'd need to pull a new circuit. (This assumes your technique is good, gotta make sure you have good penetration).
Do you need to lay beads for 10 minutes straight without stopping? Most welds on a motorcycle are far shorter than that and time spent in setup and prep negates a lot of the duty cycle concern.
Will you be welding aluminum? MIG welders usually require an add-on kit for this (spool gun).
Personally I bought a Lincoln Weldpak 3200HD kit. Nice range with 25A-135A output, 20% duty. I've never had the welder go into thermal shutdown so far. Kit includes the welder, regulator, cart, etc. Just add gas bottle.
BTW I found that I hate using flux-core wire, gas MIG is much nicer for a variety of reasons.
mystic_1
