Author Topic: Spherical 4 stroke engine  (Read 3272 times)
0 Members and 9 Guests are viewing this topic.
Offline alltherightpills
« on: July 02, 2009, 07:44:57 AM »
Saw this over on thekneeslider.com...
"Here’s a 4 stroke engine concept you have to see to understand, the Peraves Superballmotor uses a multipart sphere to replace the usual crankshaft, rods and pistons of a normal internal combustion engine.
The moving parts of the sphere have ceramic balls on their exterior which travel in grooves in the case surrounding the sphere. The rotating motion of the sphere causes the moving parts, which serve as pistons, to go through the 4 stroke cycle in 2 working chambers, which would be comparable to a 2 cylinder engine. Air and fuel are introduced at the sides near the rotating axis, are supercharged through the use of prechambers, flow into the gaps in the sphere created by the motion of the sphere, followed by compression, power and exhaust as you would expect. You have to watch the animation on their site to see the whole process because a description doesn’t work very well."
I don't know how much power this thing produces, but it looks pretty interesting.  Here is their website:
http://kugelmotor.peraves.ch/index_en.htm
78 550K
77 550K (in pieces)
71 500K0 (in pieces)
Offline hoodellyhoo
  • CB350F
Re: Spherical 4 stroke engine
« Reply #1 on: July 02, 2009, 08:02:00 AM »
Interesting, but it seems like there is a lot of friction (the surface area of the ball) and sealing issues to deal with.
Offline Laminar
  • Retsam
« Reply #2 on: July 02, 2009, 08:02:42 AM »
My first thought is that there would be a significant amount of force on the guiding balls, and it would be hard to keep them from wearing out. Also, cooling would be difficult, since you can't have any kind of coolant running through the areas that see combustion directly, and because of their relatively large thickness, air cooling wouldn't be very effective.
But cool concept, it's neat to see someone thinking outside of the box.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #3 on: July 02, 2009, 12:01:30 PM »
Not sure why the ceramic balls would be used vs some fancy cams etc. in the main crank shaft to control the movement of the 2 parts of the sphere.  I'd think they could be done away with.
Not sure how the sphere would be sealed against the motor housing to ensure good compression.'
Fun to look at anyhow.
Roule comme dans les années 70...   Roll as in the Seventies...
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #4 on: July 02, 2009, 06:52:07 PM »
looke like a great design for really high rpms
Mark Twain - Notebook, 1894
Offline themotoworks
  • addict
    • roc city cafe racers
« Reply #5 on: July 02, 2009, 07:11:31 PM »
what are the benefits?  it seems like it would have the same benefits as a wankel engine... but is it any better?
www.roccitycafe.com <- my sideline turned living
Offline KB02
« Reply #6 on: July 03, 2009, 04:35:12 AM »
I agree. Looks like a redesign of the wankle. Granted, I would love to see that Mazda RX8 engine shoehorned into a two wheeled chassis - It's not that big, it would fit rather nicely I would think.
I would like to see one of these Superball engines actually running. It would be interesting.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Laminar
  • Retsam
« Reply #7 on: July 03, 2009, 06:34:33 AM »
This one's pretty close
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #8 on: July 03, 2009, 06:44:37 AM »
The wankel has quite a bit less (actually, volumes less) friction than this spherical engine. the entire outside fo the sphere is in contact with the inside of the housing. Lot's and lots of friction there. The wankel has friction, for the most part, just at the apex of the rotor and the edges of the rotor against the combustion chamber wall.
No.
Offline crazypj
  • I'm brill, me
« Reply #9 on: July 03, 2009, 10:06:21 AM »
Cool animation, wonder if anyone will ever try and build it?
 Finally though, someone found a use for the guts from a Rubik's cube  ;D
 Could have made it four chamber, still high friction but twice the power  ;D ;D
PJ
« Reply #10 on: July 03, 2009, 11:05:35 AM »
PJ
They've made at least one, it's currently in a YP-400 scooter:
78 550K
77 550K (in pieces)
Offline Laminar
  • Retsam
« Reply #11 on: July 03, 2009, 12:48:11 PM »
Which is great until your apex seals fail at 70,000 miles and you need a new engine.  :-X
Offline edbikerii
    • Gallery
« Reply #12 on: July 03, 2009, 01:01:24 PM »
Nah, just new seals.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #13 on: July 03, 2009, 02:57:18 PM »
I wasn't commenting on longevity, but on efficiency. The more friction made, the more of the engines energy goes to just making the damn thing go.
No.
Offline Gordon
  • 750K1, 550K2
« Reply #14 on: July 03, 2009, 04:31:13 PM »
Looks to me like the friction would be focused on the 4 ceramic balls.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #15 on: July 03, 2009, 05:00:14 PM »
The combustion chamber itself is sealed by the housing. The entire surface of the "piston" requires a tight seal al the way around, meaning the entire surface of the inner ball and the entire inside surface of the housing must be touching. That's a lot of surface.
No.
Offline Laminar
  • Retsam
« Reply #16 on: July 03, 2009, 09:37:06 PM »
Not necessarily the entire ball, but probably just the silver parts in the animation. As long as those have a tight seal, the yellow parts don't have to touch.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #17 on: July 04, 2009, 07:03:56 AM »
Yeah, you have a point there, but I can't see how the silver parts there can keep a good seal over any length of time. Piston rings expand a bit with pressure, so even as they and the cylinder wall wear a bit, the 'flexibility' of piston rings will creata  good seal until they reach their wear limit. The silver bits in that animation do not appear to be able to expand to make up for wear.
No.
Offline Laminar
  • Retsam
« Reply #18 on: July 04, 2009, 07:19:41 AM »
Agreed. I would like to see a video of it running and a better pictures of that dyno chart.
