Today I am starting the rebuild of my 76 750K engine that is in my 78F.
Parts:
Gasket set (Cycle-X)
Oil Seal set (Cycle-X)
41 grind Webcam cam (Dynoman)
HD cylinder studs (Dynoman)
Adjustable cam sprocket (Dynoman)
Primary chains (mrcycles)
736 rings (Z1 Enterprises)
HD Tsubaki cam chain (Z1 Enterprises)
Cam roller and guide (Z1 Enterprises)
New OEM piston pins (epay)
Tube of Moly 60
Green plastigage
Engine Primer/Paint
Compression test with an 8" hose yielded the following results:
(1) 91 lbs.
(2) 89 lbs.
(3) 62 lbs.
(4) 61 lbs.
I picked up my engine mount adapters at 11:30 today, and started at around 12. It's 7 pm now and I'm still sweating from just coming in the house...
It was my first time pulling the engine and I did it solo. I have to say I'm feeling pretty damn cool right about now.
Carbs, gas and oil tank off
Ignition cable
Negative power feed and alternator
Main drive sprocket. Look at the nastyness that was hiding under the chain cover. I would be shot in some states!
Was a whore about coming out...
Until I pulled off the aftermarket oil cooler mount (duh!). After that, I sat down and it jumped out and on to the jack by itself. And started wagging it's tail even.
Seven hours later...
Owe my back.
