Okay I'm pretty sure I have the Lobe Center of my #1 intake correct at 107°. I apparently don't understand the difference between TDC and BDC because the readings I got were;
Intake Open 0.050 at 42° BBDC (Before Bottom Dead Center)
Intake Close 0.050 at 18° ATDC (After Top Dead Center)
I define Top Dead Center for #1 as; When the crank has the #1 piston at the top of the cylinder block. Indicated by the cam niche being at 12 o'clock and the points marker being at the "T" line for the 1-4 end. (Assuming your case's mark is accurate.) At this position both the intake and exhaust valves for #1 are slightly open and the valves for #4 are closed. This is my degree wheel's 0°/360°.
Now, I'm pretty sure I have that understood correctly, unless TDC is when the valves are closed and I've just described TDC for #4. If so, please tell me.
So what is Bottom Dead Center? Is it the 180° mark on the wheel that is also the T mark for 2-3 on the crank points? Or is it the 0°/360° mark on the wheel that happens at the cam niche's 6 o'clock?
I hope someone understands that and can help a guy out. I'm struggling.
