Author Topic: axle diameters  (Read 2354 times)
jjoe256
axle diameters
« on: July 06, 2009, 06:04:21 PM »
Can anyone verify that the diameter of a 78 CB750 SOHC's front axle is 14 mm and the rear diameter is 20mm? Thanx,Joe
Re: axle diameters
« Reply #1 on: July 06, 2009, 06:15:17 PM »
Without getting my ass to the shop I believe the front is 15mm & the rear is indeed 20.
Offline Clyde
Re: axle diameters
« Reply #2 on: July 07, 2009, 04:48:42 AM »
15mm (6302 bearing) and 20mm (6304 bearing)
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
jjoe256
Re: axle diameters
« Reply #3 on: July 07, 2009, 08:23:30 AM »
Gee,that's strange. I'm sitting here in Seattle,Wa.,USA,with a front axle off a 1978 CB750,and an axle off a 1971 CL450 and using the same caliper that told me my rear axle is 20mm,tells me both front axles are 14mm!! I made the post because I read elsewhere in the forum that it is 15mm.????
Re: axle diameters
« Reply #4 on: July 07, 2009, 08:50:22 AM »
Digital or vernier caliper? The vernier I use, because the way the lines are etched, I often an reading wrong line and am out 1mm, if I am not careful....its because the 15 25 etc is beside the line not under it. :(
jjoe256
Re: axle diameters
« Reply #5 on: July 08, 2009, 10:01:46 PM »
  :-[  Mea culpa,mea culpa. The "14"mm axle was small enough to snug up all the way in my calipers past the measuring portion,while the 20mm axle caught the measure. When I slid the "14" back into the measuring portion,low and behold it gained a mm! So,yes,the front axle is indeed 15mm. If anyone needs axles made,check out:
http://radicalcustommotorcycleparts.com/parts.aspx
My axle cost $35.
     Thanx. If I hadn't stumbled across an axle discussion,I would have ordered the wrong axle!
                                                   Joe
