Author Topic: keihin carbs  (Read 1297 times)
Offline cappy
keihin carbs
« on: November 16, 2005, 04:30:00 AM »
Just removed and disassembled my carbs.  Is there a trick in getting the float pivot pin out.  All other carbs I have worked on were a light press or slip fit.  I also have broken these cast tabs off by applying to much pressure.  Thought I'd ask if anyone has any suggestions.
Thanks,
Greg.
GTR1400 KAWASAKI CONCOURS 08'
T500 TITAN 75'
YZ250 82'
CB550 77' BUILDING
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
Re: keihin carbs
« Reply #1 on: November 16, 2005, 07:37:02 AM »
They are a press fit but can gunk up with old fuel, carb cleaner spray may help ease them.
In the UK anything over 40 years old only needs insurance and Fuel.
Offline Lumbee
    • My pics...
Re: keihin carbs
« Reply #2 on: November 18, 2005, 07:59:53 AM »
...I'v always had to pound mine out.  I used an ice pick and a small hammer...tap very lightly...and keep u'r fingers crossed  ;)
"I'm not a welder, but I play one on HondaChopper.com"
Offline Dennis
Re: keihin carbs
« Reply #3 on: November 18, 2005, 09:44:37 AM »
I just keep spraying them with carb cleaner or WD. Use correct pin punch or similar tool and tap lightly so as not to break the casting. Sooner or later you will get it. Have patience.
