Author Topic: advice on getting these damn cylinder head studs out on my CB750F?  (Read 8777 times)
Offline motomotard
    • GoGo Garage
i cant get these damn things out.  the stock ones in there are fine, but ive got a set of heavy duty ones i wanted to put in.  ive tried all of them with the double nut method and only two of them came out.
should i try heat? or is there some trick i dont know about.
what is the real benefit of the heavy duty ones anyway...
any help appreciated.
the patient....
Offline OldSchool_IsCool
  • Really feeling like an
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline michrobi
  • Goldenrod blew a 5" hole out the front with a
  • On a neverending quest for more garage space
Re: advice on getting these damn cylinder head studs out on my CB750F?
« Reply #2 on: July 10, 2009, 03:27:56 PM »
Here's how I did mine last night http://forums.sohc4.net/index.php?topic=54392.15
The studs are at the end of that page. Good luck   :)
-Mike
'78 CB750F All stock except for the powerplant. Jived it off my Dad in the spring of '94. He had it since 1980 and it's the first bike I ever rode on.
Current project: http://forums.sohc4.net/index.php?topic=67756
How's them SOHC4 patches coming?
Online MRieck
« Reply #3 on: July 10, 2009, 06:08:05 PM »
Mapp gas heat....
Offline rugger81
« Reply #4 on: July 10, 2009, 07:34:52 PM »
Take a soft rubber mallet and hit the studs till they bend down sideways a bit.  Then just spin them out by hand.  I did it using this method and had no trouble getting any of my studs out.  Ruins them of course, but you're putting in the heavy duty studs so you're good.
'77 CB750K - Rebuild Project Page
'15 Moto Guzzi Griso
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #5 on: July 10, 2009, 07:50:03 PM »
I put 2 head nuts together and turn em outwith the small impact gun and a crows foot.  makes it so they won't break
Offline gregimotis
  • poet laureate; SOHC4.
« Reply #6 on: July 10, 2009, 08:44:12 PM »
I sprayed 'em with liquid wrench and let them set overnight, then applied a short cheater bar to the bent ends and twisted them out.  Took some effort (and some nerves) but they came out alright.
HD studs can be torqued down another ten pounds or so (read directions).  they will help with any head gasket leakage you are having or might have in the future.
Offline ev0lve
« Reply #7 on: July 10, 2009, 09:27:20 PM »
Bend them a bit low on the post and turn them out? Worked for me.
I was afraid of hitting them so I put vice grips a few inches up, hand below to steady it, slow pressure at the top. They bent over pretty easily. Then just spin them out bending any others out of the way as you need to.
« Last Edit: July 10, 2009, 09:32:07 PM by Iggy »
Offline mazingerzeca
« Reply #9 on: July 11, 2009, 04:11:58 AM »
It seems to be a common problem on F2 engine. The same happened to me on the studs which are not inmersed in oil on F2 engines. Tried every method here described, and I ended having them drilled on a machine shop.
« Reply #10 on: July 11, 2009, 05:37:10 AM »
I've installed two sets of H/D studs in the last couple of years, to remove the crappy OEM studs, no fancy special tools required, just bend each stud at right angles and turn them, bend 'em back almost straight and wind them out. Not a big deal at all. Cheers, Terry. ;D
Offline dpender836
« Reply #11 on: July 11, 2009, 06:11:15 AM »
+1 on mapp gas, gets hotter than propane. Heat the stud low, but be careful not to melt the the cases, spray it a couple times with wd or pb blaster, (do this outside if you can because of the smoke)it shocks it plus lubes it, heat it back up and then use either the bent over method or double nut with a impact gun. If you get a real stubborn one you can rap the end of the stud with a ball peen hammer while it's hot. Patience is the key.
Offline motomotard
    • GoGo Garage
« Reply #12 on: July 12, 2009, 07:51:49 PM »
still dont have these out.  went to HF to get the stud extractors and they didnt have em.
i like the bending them idea but am afraid that if i do that and it still wont come out ill be stuck with a bent up stud
Online MRieck
« Reply #13 on: July 12, 2009, 08:02:32 PM »
Heat them up....get the top case hot. They are seperated right?
Offline timdhawk
  • 1978 CB750K
« Reply #14 on: July 12, 2009, 08:46:48 PM »
i just used a small pipe wrench last night. worked great! took about 30 mins for all of them.
In deeper than I should be...
« Reply #15 on: July 12, 2009, 08:55:59 PM »
When you guys double nut them, is it at the top, or bottom....?
 looks like they would pass over.
Offline gregimotis
« Reply #16 on: July 12, 2009, 08:59:18 PM »
Do It - it'll work.  And if it doesn't, you still have the HD's waiting, so you still have to get them out somehow - bend 'em, heat 'em, lube 'em, they will come out eventually.  Chance favors the bold.
« Reply #17 on: July 13, 2009, 05:26:59 AM »
How the "F" can you "double nut" them at the bottom Frank? They're screwed right into the cases with no exposed thread! Are you on the drugs mate? ??? ::) ;D
Offline jtb
  • An unlikely
« Reply #18 on: July 13, 2009, 05:40:21 AM »
A bit testy this morning, are we? ;D ;D ;D
1977 CB750F
1985 V65 Sabre
« Reply #19 on: July 13, 2009, 05:48:26 AM »
Ha ha, nah, just drinking Kentucky Bourbon and wondering what Frank's on John, it must be way stronger than Jack Daniels! ;D
Online MRieck
« Reply #20 on: July 13, 2009, 06:21:41 AM »
...and I thought it was just me who can get pissy... :D :D ::) ;)
« Reply #21 on: July 13, 2009, 08:39:25 AM »
 Yeah, wasnt thinking when i posted that one..... :-[
 I was thinking about how it mist "wind up" when double nutted, as opposed to gripping near the bottom... just hate ruining parts.
Offline scondon
  • Mmmm......tasty bugs
« Reply #22 on: July 13, 2009, 09:12:56 AM »
I've done this with three F2 cases so far. I broke at least one stud on every one of them trying to get them out.
Heat, lube, and impact are key, especially the heat.
    I had a broken stud in the case I'm using. I pooled PB Blaster at the base and threw the case on the bbq grill. Using a stripped nut removal socket (these things are GREAT, socket with a conical shape and reverse spiral cutting edge. The more you turn to loosen, the deeper they bite), I hit the socket with a hammer while turning it with a wrench and that pesky stub came out in short order.
« Reply #23 on: July 13, 2009, 01:44:27 PM »
Terry,
One more F'Up like calling Tennessee swamp water (aka Jack Daniels) Kentucky Bourbon and I'll have your Maker's Mark Ambassadorship revoked!  ;D
Offline motomotard
    • GoGo Garage
« Reply #24 on: July 13, 2009, 02:14:30 PM »
thats what im worried about, breaking the #$%*es in half or something
gonna try again in a min with some heat
