Author Topic: Honda CB550 rim and tire sizing questions......  (Read 9929 times)
Offline Johnny-5
« on: July 10, 2009, 11:55:16 PM »
I know stock fronts are 19" and rears are 18" but whats the width on them?
Im building a cafe racer and was just curious what people would recommend for my rim and tire sizing. Should I stay 19" fronts and 18" rears or is it ok to go 18" all the way around? Also whats the widest tire width our bikes could handle?
Offline shizzomynizzo
  • It's 5 o'clock somewhere
Re: Honda CB550 rim and tire sizing questions......
« Reply #1 on: July 11, 2009, 01:12:42 AM »
this has been asked before, i looked it up a few weeks ago.
if i'm not mistaken, front is 3.5 and back is 4. back can go as big as 4.5; the wider you go, the worse it handles and more uneven it wears
check the faq
1974 CB550
1985 XLX Last of the IH
2001 Street Glide
« Reply #2 on: July 11, 2009, 01:53:54 AM »
The stock rim widths for the Cb550 are 1.85 inches front and rear.  This is the measurement from bead to bead on the rim and where the tire seats.
Tire manufacturers usually list the rim width their tire is designed to fit upon.  It takes some research sometimes to find it.
Otherwise, use the tire size specified in the owners manual.
Offline Johnny-5
« Reply #3 on: July 11, 2009, 09:23:04 AM »
Thanks for the posts....I know its probably best to stay with factory spec's but a shop Ive been talking to recommended me to go with the following:
18x2.15 rim with a 110 Tire Front
18x3.5 rim with a 130 Tire Rear
What do you guys think?
« Reply #4 on: July 11, 2009, 11:43:59 AM »
Do you just want it to look good or do you want it to handle nice and neutral like it did from the factory?  You know, where you can steer the bike by thinking or leaning into the turn instead of wrestling with the bars to hold your line in a corner?
The stock set up would allow enough lean over to scrape the pegs in the corners.  What, exactly do you expect to get from wider tires?
A smaller front wheel will lower the bike and change the head angle, making the peg scraping thing occur at less lean angle among other things.  I suppose it will look more modern in the parking lot, though.
So, what do I think?
I think the shop makes more money on wider rims and bigger tires than they would make selling you the correct or nearly correct size tire for your bike.  They certainly don't have to actually ride the bike and then spend the time and energy working out actual performance improvements.
How much will you invest to work out the handling differences, or will you just live with (or sell) the resulting experiment?
You might want to list the goals of your endeavor, in order to get a more reasoned response to your query.
