Author Topic: No cost tire balancer  (Read 5698 times)
Offline lowmileage
  • Gotterdone
  • At Montauk Point Circa 1975
« on: July 13, 2009, 07:34:12 AM »
Got this idea yesterday and seems to work great.  Seems everyone has a picnic table and benches.  Last photo shows where tire settled (heaviest point) out of 6 tries.  While it didn't settle on the same point, it gravated on 3 spots that were close by - starting at the valve.  While it appears the valve is at the bottom, the middle of the 3 marks was actually just after the valve hit mid bottom.   I'll figure the heaviest in the middle and line the "tire dot" up with that spot.  I put the valve in the rim first before spinning.
« Last Edit: July 13, 2009, 07:41:15 AM by lowmileage »
1975 750 K5 Original owner -  11K miles.  On the road 8/09 after 26 years in storage.
2004 Harley Superglide - bought new
1973 Honda CL350 - sold in '75 to buy the "750"
Offline lynchj
  • Life is short ...go for a ride now
Re: No cost tire balancer
« Reply #1 on: July 14, 2009, 02:02:41 PM »
Sweet  :)
The KISS principle in action (Keep It Simple Stupid) not that I'm iplying that you are stupid, it's just an expression.
my CB500 build thread   http://forums.sohc4.net/index.php?topic=54143.0
Other toys: 98 YZ125, 70 MGB, 99 Camaro
Offline rbmgf7
  • 2>4
« Reply #2 on: July 14, 2009, 02:46:39 PM »
As this is a great 'at home' idea, I think it would still be recommended that you take it to have it professionally balanced. Although you may have it balanced from spinning the wheel by hand, once you accelerate the wheel, just the smallest counterbalance is going to amplify significantly. It just wasn't enough to overcome the resistance in your bearings while you had it balanced on the bench. You might want to also wait and get a tire installed before you balance the wheel. The shop in town only charges a few bucks to balance a wheel off the bike
« Last Edit: July 14, 2009, 02:55:10 PM by rbmgf7 »
Offline lowmileage
  • Gotterdone
« Reply #3 on: July 15, 2009, 06:03:05 AM »
****suckers in my town wanted a hundred bucks to mount and balance tires (tires that they wanted to charge me full list price on) that I brought in off the bike.  David Kirk got my business and I'll put my own tires on - and people want to know why you don't buy locally  ::) .  Static balance has always worked for me - up to 100 mph anyway.  I balanced the wheel first to get the heavy spot - to which I'll line up the tire dot up to (if it has one).
« Last Edit: July 30, 2009, 01:35:51 PM by lowmileage »
Offline Clutch Cargo
« Reply #4 on: August 08, 2009, 05:08:52 PM »
Dynabeads is another low cost option
http://www.innovativebalancing.com/
1976  CB750K6
1976 GL1000
1994 - ST1100
1985 - HRS21
Offline CBGhia
« Reply #5 on: August 10, 2009, 01:51:17 PM »
I used those and they seem to work pretty well.
Offline Hinz
« Reply #6 on: August 28, 2009, 01:30:09 PM »
brilliant! AND you have a place to sit while you do the balancing!
 :D
1976 CB750K
Has learned so far that..."complete" gaskets are never complete no matter where you get them, VHT Silver Case Paint is just as durable as painting your motor with chalk and cheap tire irons used with rim protectors are useless on 30 year old tires.
Offline fmctm1sw
« Reply #7 on: August 30, 2009, 07:31:03 AM »
I see they have a motorcycle specific package for those beads.  I assume the wheel size determines how much you need to buy   ???  I wonder what that equation is...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
