Author Topic: 750F thread?  (Read 181314 times)
Offline aperry
Re: 750F thread?
« Reply #800 on: May 20, 2012, 09:56:24 AM »
Thanks Jerry.  The 9" measurement is at the bolt area (hence the bushings comment), correct?
Any idea what the measurement is between the inside faces of the swingarm at the location where it holds the axle?  I am expecting this to be somewhere around 9 and 3/4 inches.  My 75/76 F axle is about 3/16" longer than my K axle.  I want to confirm the swingarm is also wider where it holds the axle.
Thanks again,
Aaron
(edited to correct "axle" spellings!!  I have a German friend named Axel, and it's really messed up my spelling....)
« Last Edit: May 20, 2012, 09:59:50 AM by aperry »
CB750K3 with F1 frame/swingarm
Re: 750F thread?
« Reply #801 on: May 20, 2012, 10:04:07 AM »
The 9" is at the bolt from outside bushing edge to outside bushing edge.
Not exactly sure what you're asking but I just measured my spare frame. The opening for the swing arm is 9 5/16". I'll be out in the garage playing after I get off here and can insert the swingarm and check that 5/16" clearance?? Get back later.
Offline david 750f
  • 1976 CB750F
Re: 750F thread?
« Reply #802 on: May 20, 2012, 10:18:19 AM »
Are you looking for the inside width of the swingarm where the rear wheel axle passes through?
Measures approximately 10 inches on my spare NOS swingarm.
1976 CB 750F
Offline ChuckG750f1
  • Not your average, everyday, run-of-the-mill
Re: 750F thread?
« Reply #803 on: May 20, 2012, 10:19:34 AM »
I missed this thread.  Just wanted to add my f1 to the group.  I've posted this in a couple other threads but it's the nicest pic of my 750 so far.
Life is hard; it's harder if you're stupid.
- John Wayne
1976 CB750 f1
1995 HD Softail Custom
Offline aperry
Re: 750F thread?
« Reply #804 on: May 20, 2012, 10:30:42 AM »
Yup, that's the one I'm looking for.  Little larger than I thought (by about a quarter inch), but probably workable.  Thanks!
Offline RSchaefer
Re: 750F thread?
« Reply #805 on: May 20, 2012, 10:33:21 AM »
BEAUTIFUL F1 Chuck!!  Wish I could find a stock muffler for mine!
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Re: 750F thread?
« Reply #806 on: May 20, 2012, 12:15:54 PM »
Who's installed CR carbs on their F? What about the throttle cables? Any tricks? Advice?
Offline ChuckG750f1
Re: 750F thread?
« Reply #807 on: May 20, 2012, 12:27:00 PM »
Thanks, it's got age marks but so do I ;). I didn't realize that the stock muffler was so hard to find but someone else asked me if I wanted to part with it.  I was thinking of changing it but the bike runs great (stock intake & exhaust).
- John Wayne
1976 CB750 f1
Offline RSchaefer
Re: 750F thread?
« Reply #808 on: May 20, 2012, 12:35:44 PM »
Regarding the exhaust - its hard to find a long muffler replacement.  Everything out there is much shorter.  I personally think the "F" looks better with the longer exhaust, not so much the "K," but the "F" specifically and there just hard to find with that 2 inch opening.
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline gearhead ed
Re: 750F thread?
« Reply #809 on: May 21, 2012, 02:27:09 AM »
The muffler on my 78f was rusty on the end so I bobbed it and made a new baffle. Turned out pretty good.
1978 750f    1964 Chrysler 300
Offline RSchaefer
Re: 750F thread?
« Reply #810 on: May 21, 2012, 06:26:45 AM »
I have 3 or 4 quarter size holes or larger back at the front end of the muffler, closest to the collector.  Originally I was thinking I could take it to a muffler shop and have it repaired but I think that would be a BIG job, grinding down the welds, re-chroming, etc.  I purchase a replacement megaphone from Don here on the forum that is from a truck muffler, flared end and a baffle he installed, stainless, tab for the stock mount, looks real good, just not LONG like the stocker.
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline gearhead ed
Re: 750F thread?
« Reply #811 on: May 21, 2012, 09:53:20 PM »
How does don's muffler sound compaired to a stocker?
Offline RSchaefer
Re: 750F thread?
« Reply #812 on: May 22, 2012, 05:28:52 AM »
I wish I knew as she is mostly in pieces at the moment.  I am just getting the engine back together after a cylinder hone and port job.
Don has road tested it both with the baffles and a 2nd option with less back pressure he offers.  The muffler looks good and as mentioned is stainless.
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline ChuckG750f1
Re: 750F thread?
« Reply #813 on: May 22, 2012, 07:23:38 AM »
This is what I've been considering as an alternative to the stock muffler:
http://www.coneeng.com/pdf/motorcycle/MC%20finsihed%20Mufflers%20PDF.pdf
They sell everything one would need to make a longer, stock style too.
- John Wayne
1976 CB750 f1
Offline RSchaefer
Re: 750F thread?
« Reply #814 on: May 22, 2012, 08:25:44 AM »
Here is Don's thread http://forums.sohc4.net/index.php?topic=61446.0
Here are some pictures:
 Stock Muffler & Don's in a box
Measurements of Stock Muffler
Don's Muffler, Tab & Clamp
Don's Insert
Unless I am missing something I am not seeing but maybe one choice on the link you included that would work?  We need like a 2" & 7/8" or 3/4" inlet and the stock muffler is over 30" long.
Don's includes a nice stainless clamp and he has welded on a tab at the correct location.
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline Picasoo
Re: 750F thread?
« Reply #815 on: May 23, 2012, 02:55:41 AM »
Fresh pics of my 75F
Greetings from Serbia...!
'75 cb750F super sport
Re: 750F thread?
« Reply #816 on: June 01, 2012, 12:20:36 AM »
G'Day Jerry, I installed mine on my K1, but with the same throttle assembly as you've got on your bike, and the stock cables worked fine.I've seen a post from someone else saying that the cables need to be modified to fit, but that wasn't my experience, then I realised that his bike was an F2, with different throttle assembly and cables than ours. I'd just about bet that your OEM K1-F1 throttle cables will work fine without any mods. Cheers, Terry. ;D
Offline drpepper79
Re: 750F thread?
« Reply #817 on: June 02, 2012, 11:27:13 AM »
I have a 78 cb750f  i love this bike well it is my first bike too i will post a pic of it as soon as i can
Offline bruzer59
  • 1977 CB 750F
Re: 750F thread?
« Reply #818 on: June 02, 2012, 12:35:02 PM »
here is my 1977 F . i have owned this bike  since 1984 !!!
 i just finished painting a pair of tail pieces for my bike ..
    ITS GOOD TO HAVE SPARES OF EVERYTHING
« Last Edit: July 11, 2012, 04:24:35 PM by bruzer59 »
Re: 750F thread?
« Reply #819 on: June 02, 2012, 05:13:31 PM »
Looks nice! How'd you paint?
Any spare seat trim or tail piece trim?
Offline bruzer59
  • 1977 CB 750F
Re: 750F thread?
« Reply #820 on: June 02, 2012, 07:28:51 PM »
  HEY Jerry Rxman Griffin ..  Thank you
3 coats Rustoleum, Cobalt Blue Metallic  ...    With 4 coats of U-POL clear coat
  as for the trim .... no im sorry i do not...
Online Don R
Re: 750F thread?
« Reply #821 on: June 20, 2012, 03:12:51 PM »
On an F how far can you go on main gas before hitting reserve? I got 158 miles today and started to doubt my reserve valve working properly. I stopped and filled it up 3.9 gallons approx 40 mpg. I know they can do better but it's way better than the 93 miles it used to go.
Re: 750F thread?
« Reply #822 on: June 20, 2012, 03:35:20 PM »
Don,
That's probably average IMO. If I'm not in the throttle too much and highway cruising I was getting 45mpg with the 812. Probably close to 150+ usually before reserve most of the time. Book (Honda Service Manual) says tank is 4.3 with 1.3 reserve but it says the 77 is 4.8 with 1.2 reserve. I tend to believe the 77 numbers because I was thinking it is 5 gallons.
Online Don R
Re: 750F thread?
« Reply #823 on: June 20, 2012, 08:40:06 PM »
OK thanks, it bogged a little at 150 and I switched back and forth between main and reserve with no result. Maybe some moisture, it is Hot and Huuumid here. I put  a new fuel screen on the petcock  last summer after Topeka and before Chicago. I didn't realize how rich it was running until after I fixed the floats. it's surprising how many things a big dumb PO can find to mess up.
Online Don R
Re: 750F thread?
« Reply #824 on: June 20, 2012, 08:49:04 PM »
A quick story. I met my brother at our favorite breakfast spot and parked my Honda out front. I was seated and the counter after a few minutes a car left and then you could see my bike out front. There was a couple seated at a table near the door, I hadn't noticed but the man went out to look at my 76F. When the waitress pointed at him, I noticed his wife was smiling and looking out the window. I remarked he must have had a bike like that one. she said no, not like it. He owned that bike for 25 years. When he came in he told how they bought it in 1980 and rode it all over Colorado. They got a scare and she stopped riding with him soon after it was parked for around 20 years. I now know every owner except the first one, we will be talking about that. He was happy to see it all shiney and running and of course, he offered to buy it back but I doubt he would like the price.
And no, he was not the big dumb PO. He was the good one.
« Last Edit: June 20, 2012, 08:52:53 PM by Don R »
