I'M thinking of different design angles for the attachment of the covers. Threaded lugs as HONDAMAN and 754
suggested, bolts from the backside, longer studs with a hole drilled through the side for a pin or cotter key to
hold it on and for security. I have a real good friend that is a retired santa fe machinist and has a machine shop in
his garage. I will see if he can help me with the lug situation, if not, HONDAMAN I'll be getting ahold of you !
![Grin ;D](http://forums.sohc4.net/Smileys/default/grin.gif)
The real #$%* of the process is i'm gonna have to butcher a cherry set of covers to section them and to add larger
bosses because of the shrinkage for when the aluminum cools. The foundry calculated about a 1/4 inch shrinkage
total ! Anyway, thanks for your input guy's. JON G.
