Author Topic: CB 500 fork question  (Read 1629 times)
Offline boulder74
  • '75 CB 500 Cafe...almost done
« on: August 19, 2010, 09:58:46 AM »
I really want to get rid of the fork boots on my ride and go with the cleaner look of the 750 fork tubes.  The condition of mine are 'ok' up inside the current boots and ears but would like to change the stock ears out when I tear it down this fall.
Can I swap out my '73 500 forks for any others such as 750 or 550's ?  Or are there any recommendations on seals/new forks/swaps/etc?
Pics are: current (black); and look I'd like (red)
Thanks
Offline brett_bike
  • '73 CB500 Four K2
Re: CB 500 fork question
« Reply #1 on: August 19, 2010, 10:19:33 AM »
If your tubes are still good under the fork ears, there is no reason to replace them.  You can use your existing fork legs, you just need to get new for ears and dust seals.  While you're at it, completely rebuild the forks and install tapered steering bearings.  You won't regret it.
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
« Reply #2 on: August 19, 2010, 11:25:59 AM »
750 tubes are too big, won't fit.
550 tubes are what you want, they were
made to be used without the rubber boots
so the hard chrome goes the entire length
of the tubes.
Bikes parked out front mean good chicken-fried steak inside.
Offline boulder74
« Reply #3 on: August 19, 2010, 12:33:27 PM »
Sweet, thanks a ton!
Been looking around but not sure if I was looking at the right stuff, now I'll know for the 'frame-up' this fall.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #4 on: August 19, 2010, 01:46:00 PM »
'77 and newer came with dust seals instead of boots.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline bradweingartner
  • 74 CB 550 x2
« Reply #5 on: August 21, 2010, 05:27:37 PM »
of the tubes.
Careful, only the later 550 were chromed the entire length.
Offline boulder74
« Reply #6 on: September 02, 2010, 06:58:00 AM »
Do you know which 'later' years those are by chance?
« Reply #7 on: September 02, 2010, 09:39:56 PM »
77/78 were the ones, also 500 twin but they may be a slightly different length
  • 74 CB 550 x2
« Reply #8 on: January 28, 2011, 12:40:27 PM »
of the tubes.
I thought both 750 and 500/550 tubes were both 35mm in diameter.
This thread also recently came up: http://forums.sohc4.net/index.php?topic=37104.0
Offline apex_seeking
  • Ron Swanson is a
« Reply #9 on: January 28, 2011, 01:39:56 PM »
Thanks
I'm sorta doing what you are. I have a 75 550 and just swapped a member my stock boots. After I pulled the boots I thought it might be nice to run just a dust boot and not the gaiters.After a little research and some help from the people here, I found the 750 k2 came with the dust boots and fits our bikes. They are both 35mm.
« Reply #10 on: January 29, 2011, 07:08:40 AM »
Dust boots are a 500 twin part and only they and the 550K3 had fully chromed tubes
