Simple,rebuild ,clean whatever,fill reservoir to proper level ,tighten cap,turn so facing where line bolts up,slowly very slowly pull lever,if fluid appears,great,install,if not pour tiny bit of fluid in hole ,slowly pump,air will start to purge itself in a pump or3,if correct fluid will start to flow,install,saves lots of time and pumps!Bill
