As requested.. I am reporting back... and the results are...
001.0 between the rotor slip rings..
If that is a 1 ohm reading between the two slip rings, you will need another rotor.
It does contradict the 15-29 ohm reading you reported earlier at the white and black wire. The two readings are supposed to very nearly the same.
You should also check ohms from brush contact to wire end, either white or black, each brush.
Maybe the continuity loss along that path saved your R/R? Do fix your rotor before you hook up the R/R to it.
