Author Topic: Shoot me please :( oil gushes out of generator and fills stator cover  (Read 6096 times)
Offline checkflag
Re: Shoot me please :( oil gushes out of generator and fills stator cover
« Reply #25 on: July 21, 2009, 06:14:05 PM »
Assuming you can find the Vreg/rec combo.  You want to remove the black and white wires that go to the alternator. And measure the resistance between them.  S/B around 5 ohms-ish.  Report your findings.
If significantly lower than that (be sure to subtract what your meter reads with the probes simply touched together), then the rotor is bad.
If significantly higher than 5 ohms, retest directly on the rotor slip rings under that cover.  If normal res. there then you have a wire or brushes problem.
If the rotor is very low ohms now, it can damage the R/R from the over-current it draws.
Let us know what you find.
Thats all good and all, but I do not know where any of those wires are. could you tell me where theses b/w wires are?
if you have the patience, A photo would be great. I am a visual person
« Last Edit: July 21, 2009, 06:16:47 PM by checkflag »
1979 cb650. Mac 4-1 exhaust. Soon>> cb750 carbs.
« Reply #26 on: July 21, 2009, 06:36:54 PM »
I don't have a 650, only 550s and 750s.  Someone else will have to make pictures for you.
I know charging systems and how to read a wire diagram.
I take it you have no shop manual for the bike, either?
Offline checkflag
« Reply #27 on: July 21, 2009, 06:50:01 PM »
i have the factory manual.. It vague. there are several combinations of black and white wires in the plugs
between the alt/rotor and the reg/rec
if these are the correct wires, than this is the result.
NOTE : with the leads reversed.. the reading was about 15
« Last Edit: July 21, 2009, 09:22:49 PM by checkflag »
« Reply #28 on: July 21, 2009, 10:22:44 PM »
29 ohms is far too high.
Time to check the slip rings for glazing.  And, the brushes for proper contact.
Need resistance measurement AT the slip rings.
Maybe polish the rings with 400 grit abrasive to make it bright and shiny.
Offline checkflag
« Reply #29 on: July 21, 2009, 10:27:26 PM »
I didnt know what to connect what to.. red to white, black to black??? anyway, when i reversed the red/black leads I got a 15 reading.. but also to high.
I opened the alternator and I guessed that the "rings" are the opposing magnets..  ???
Placing the leads between them, the #'s went all over the place. it was khaos. Maybe I did it wrong.
« Reply #30 on: July 21, 2009, 10:37:45 PM »
Follow the wires into the alternator cover.  See it attach to two spring loaded brushes.  See where the brushes push against the copper rings on the rotor?  Those are the slip rings.  If they aren't copper colored, then clean them with the 400 grit until they look like copper.  Make your resistance measurement.  Report findings.
Those slip rings deliver power to the alternator field coil.  The field coil is an electromagnet.  The strength of the magnet determines the size of the magnetic field that creates power in the stator.  If the field coil resistance is too high, you will get low/no power output from the stator.
Offline checkflag
« Reply #31 on: July 21, 2009, 10:46:07 PM »
ok.. thank you.. see,I was way off target.. :)
I will check this out.
Offline checkflag
« Reply #33 on: July 22, 2009, 10:49:02 AM »
As requested.. I am reporting back... and the results are...
001.0  between the rotor slip rings..
Offline lowmileage
  • Gotterdone
  • At Montauk Point Circa 1975
« Reply #34 on: July 22, 2009, 10:54:52 AM »
 :o  shoot you  8) .  Can't oblidge unfortunitely  >:(.  The government doesn't want me to have a gun  :(.
1975 750 K5 Original owner -  11K miles.  On the road 8/09 after 26 years in storage.
2004 Harley Superglide - bought new
1973 Honda CL350 - sold in '75 to buy the "750"
« Reply #35 on: July 22, 2009, 12:11:51 PM »
If that is a 1 ohm reading between the two slip rings, you will need another rotor.
It does contradict the 15-29 ohm reading you reported earlier at the white and black wire.  The two readings are supposed to very nearly the same.
You should also check ohms from brush contact to wire end, either white or black, each brush.
Maybe the continuity loss along that path saved your R/R?  Do fix your rotor before you hook up the R/R to it.
Offline checkflag
« Reply #36 on: July 22, 2009, 12:30:17 PM »
I know, the continuity is strange. Maybe I did the b/w wires wrong.
So.. about this brush contact to wire end. I dont know where to look for these. (sorry)
I know the brushes.. but will I need to remove the stator for the wire end part?
« Reply #37 on: July 22, 2009, 12:44:39 PM »
Each wire black and white connects to its corresponding brush.  You need to place the probe on a brush and brush and measure the resistance to the end of the black or white wire.  Then do the same with the other brush.
The stator mounts in the cover.  You can access the brush ends with the cover removed.  I don't see why you have to remove the stator from the cover.
