Author Topic: 750K4 - Should I Buy - Update...  (Read 8218 times)
Offline mrbreeze
  • Not your average
Re: 750K4 - Should I Buy - Update...
« Reply #50 on: August 06, 2009, 03:15:04 PM »
I also have the right side 341's that are in ok shape allthough the baffles are gone.The left side pipes are blown out on the bottoms but could probably be repaired by the right person. I recall someone saying the left ones usually go first due to oil off of the chain. I have headlite ears but the left side is kinda tweeked from a tip over. I haven't seen it for awhile (packed away in boxes but might be repairable.)
MEMBER # 257
« Reply #51 on: August 06, 2009, 09:52:54 PM »
Sorry Breeze but I think when this bike is done, its going to be BETTER than what the guys were rolling off the showroom,any comments Johnie-
Online Johnie
« Reply #52 on: August 08, 2009, 06:18:42 AM »
Mr. Breeze...thanks for keeping me in mind.  If you run across the ears please let me know what you have there, condition and all.  I am still on the hunt for those dang ears.  Ebay was close, but those are all for the 1972.  These ears are specific as they have a seperate hole for the blinker stud in the middle of the ear area.  See the pic...click to enlarge.  Thanks again for checking.
« Last Edit: August 08, 2009, 06:20:18 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #53 on: August 08, 2009, 06:44:12 AM »
John, are the '72 ears otherwise the same dimensionally? Could you drill them? I know, not original, but might work otherwise if they are until you find correct ones.
Online Johnie
« Reply #54 on: August 08, 2009, 07:46:00 AM »
You are correct Bob...they look the same except missing the hole.  I thought about your idea earlier, but you would have to add some strength to the ear as that thin metal would bend easy without it.  Then you would have to rechrome and stuff.  Since the ears, forks, and steering bearings will be done in the winter I have time to keep up the hunt.  Guess the search is half the fun.
Oshkosh, WI  USA
« Reply #55 on: August 08, 2009, 08:26:54 AM »
The K4 was also the 'era' when the fork ears changed from having the K2-like hole for the blinker, with longer, tapered stalks for those lights, to the shorter stalks that came out the headlight mounting nuts (cheaper to make). here's a shot of the Hondaman Special, showing K4 ears with K2 turn signal stalks. For this bike to be otherwise perfectly period correct, the shorter stalks would have to be installed, but I only have rusty ones right now. I wanted for Bryan to have a nice chrome set, at least.  :D
It does cause the turn signals to be emphasized, though: never a bad thing when riding in traffic.
Online Johnie
« Reply #56 on: August 08, 2009, 11:35:42 AM »
Now you have me confused Hondaman...my parts book shows the correct blinker stud for the K3 & K4 as the longer stud.  It shows the short stud for the K2 only.  Plus, I have a K4 brochure that shows the longer studs like in the Honda parts book.
Oshkosh, WI  USA
Offline myhondas
  • Not really such a
« Reply #57 on: August 08, 2009, 02:20:07 PM »
Johnie,
you have it right....the longer tapered stud was 74 era... like the pic that I sent you. if worse comes.... I will basically give you mine in that pic....they will need to be cleaned and rechromed though.  even hondaman can type confuse stuff huh....
ray
« Last Edit: August 08, 2009, 02:22:13 PM by myhondas »
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
Online Johnie
« Reply #58 on: August 08, 2009, 03:06:39 PM »
Johnie,
ray
Thanks Ray...I did find NOS OEM blinker studs last week.  I sure appreciate the offer.  Now if you happen upon those fork ears...I am all ears!!!  ;D
Oshkosh, WI  USA
Offline myhondas
  • Not really such a
« Reply #59 on: August 08, 2009, 04:52:03 PM »
sorry, i meant the ears in the offer. I think I have decided to part out the bike rather than rebuild it...but then I am not firm on that.
SOHC# 5105 11228
Online Johnie
« Reply #60 on: August 08, 2009, 05:44:34 PM »
;D I hate to take your ears if you are not sure yet.  Let me know when you decide for sure.  I am in no big hurry so you can think about it for a while.  Are they straight?  I had planned to rechrome anyway so that is no big deal.  I saw some on eBay but they were rusted almost through the metal.
Oshkosh, WI  USA
Offline myhondas
  • Not really such a
« Reply #61 on: August 08, 2009, 06:10:20 PM »
Just went out and looked at them real close.... Both have some good rust on them,.....right one could be used, but left has a 1" x 3/8"  hole rusted through on the tube below the ear.... so...not sure you can use both of them, but if you want them, I'll pull them off.
SOHC# 5105 11228
Online Johnie
« Reply #62 on: August 08, 2009, 06:39:00 PM »
Thanks for looking them over.  Since I am not in a big hurry, leave them on the bike for now.  You may decide to restore it too.
Oshkosh, WI  USA
Online Johnie
« Reply #63 on: August 10, 2009, 04:25:58 PM »
Per Bob's request, here are a couple pics of the new 341's installed today.  Took a bit as I wanted to get the bottom of the engine cleaned and both kick stands repainted before I put the exhaust on.  Now I have to check the points, timing, etc.  Starts hard but I know the points were pitted and probably out of adjustment too.  The look is really an improvement with the OEM seat, sissy bar gone and exhaust in place.
« Last Edit: August 10, 2009, 04:27:52 PM by Johnie »
Oshkosh, WI  USA
« Reply #64 on: August 10, 2009, 04:36:39 PM »
Looking good Johnnie!
Reminds me of something.... ;)
cheers
Andy
Online Johnie
« Reply #65 on: August 10, 2009, 06:17:37 PM »
Looks hot there Andy!!!  Hey, would you suggest just some model paint for the white lettering and black edging on the HONDA emblem on that tank?  Sure would improve the look once I get that painted.
Oshkosh, WI  USA
« Reply #66 on: August 10, 2009, 08:16:25 PM »
Nope Id recommend a NEW HONDA badge - the pearl white paint with gold underlay is quite special  ;)
« Reply #67 on: August 10, 2009, 08:16:59 PM »
Looks nice Johnie.Have you heard the pipes yet?? I have touched up the white and black on the tank emblems before with Testors and a very small brush. The white is kind of "thin".fairly translucent,will need several coats. One hint is to leave the little bottle of white open for awhile so it can evaporate some of the thinner off and become a little thicker.Try to keep it in the low areas which is almost impossible,but when you are done,take a small block of oak wood and some very fine wet/dry paper and "sand" gently the high spots or top of letters to remove slop etc. and which is already an unpainted metal and it will look really professional and make the letters really pop.Sidecovers can be done the same way but do not let the paint cure really good and very gently sand with 1200 grit or use a fingernail as those are chromed plastic.This is my 836 with crappy emblems Looking forward to future updates. Eric
Online Johnie
« Reply #68 on: August 10, 2009, 08:31:38 PM »
New badge?  From where???  Honda says nope.
Oshkosh, WI  USA
Online Johnie
« Reply #69 on: August 10, 2009, 08:34:30 PM »
Thanks for the details Eric.  I have to figure out what I am going to do.  I do not think I can find the OEM tank badges.  I have not seen this style on eBay either.  Oh, I did hear the pipes and they are quieter than the 300's for sure.  But I still like having a stock bike.
« Last Edit: August 11, 2009, 09:56:58 AM by Johnie »
Oshkosh, WI  USA
Offline Simpson
  • I ain't no
  • Aged to perfection
« Reply #70 on: August 10, 2009, 09:21:45 PM »
looks great Johnie! A fun project. That bike was lucky to find you as a home.
Any detectable issues with your compression?
The numbers seemed fine.
1970 CB750 K0
1975 CL/CB 360 Mix
« Reply #71 on: August 10, 2009, 09:37:46 PM »
Hi Johnie, try Z1 enterprises for the tank badges... ;)
http://www.z1enterprises.com/detail.aspx?ID=2129
Online Johnie
« Reply #72 on: August 11, 2009, 05:46:40 AM »
Thanks.  They list that as K2 - K5, but those are different than the K4 but are correct for the K2.  The OEM has a straight edge across the top.  See pic below.  The Z1 metal plate follows the contour of the letters which is not period correct.  Maybe I should give them a call.  I did check Yamiya, cmsnl and silver spares with no luck.
« Last Edit: August 11, 2009, 12:44:11 PM by Johnie »
Oshkosh, WI  USA
Online Johnie
« Reply #73 on: August 11, 2009, 09:54:26 AM »
I have not checked the compression since the first time I saw the bike.  Points were pretty far off and were pitted.  I cleaned them up with a points file and reset.  Carbs are done.  Timing light burned up last night.  Coming along nice.  I still need to locate the fork ears and tank badges.  Started hard yesterday, but that was before I checked the points.  Should get better as I time and do the valves.  I should really put a new set of points in there too.  So in a nutshell, I am now working the bugs out of it.
« Last Edit: August 11, 2009, 09:59:58 AM by Johnie »
Oshkosh, WI  USA
Offline myhondas
  • Not really such a
« Reply #74 on: August 11, 2009, 11:34:27 AM »
Sounds like you are moving right along...... tank decals will be hard to find. You will probably have to restore yours or find some that are in good shape at  a bike salvage yard.... or .... check around....here are a few places that are good for the 750....
http://www.babbittsonline.com/
www.hdlparts.com/default.asp
www.davidsilverspares.co.uk
www.cmsnl.com
www.hondanuts.com/cb750.html
www.loudfastugly.com
www.cb-4zylinder.de/index.html
www.four-schmiede.de (German)
www.honda-cb-four.de (German)
www.sayonara-cycles.de (German)
www.classicbikes.com
www.cycle-salvage.com
www.denniskirk.com
www.servicehonda.com
www.westernhillshonda.net
www.cb750.org
www.hondacb750.com.au (Aussie)
http://cb750k2.tripod.com/page1.html
www.stilettocycle.com.
SOHC# 5105 11228
