Author Topic: HRC Clutch Basket  (Read 18497 times)
  • Moderator
Re: HRC Clutch Basket
« Reply #25 on: October 01, 2009, 03:42:39 pm »
Seems he is local to me and lists being a fan of me ;D ;D ;D ;D ;D ;D
http://www.facebook.com/people/Alan-Jackson-Jnr/667097989
Sam. ;)
  • Moderator
« Reply #26 on: October 01, 2009, 03:59:07 pm »
I've sent him an email, you may be able to ask him yourself TG. ;)
Sam. ;)
  • Moderator
« Reply #27 on: October 01, 2009, 09:12:42 pm »
TG, I received this email from Alan, seems it was his dad but he will let him know.
I'm off line now untill Monday night, so keep your eye on this thread for a newbie.
Sam. ;)
Alan sent you a message.
Re: Re your 77 TT f2 win.
Sam, Thanks for the message, Its actually my dad you need to talk with. I will mention it to him and look at the forum.
We will be in touch.
Cheers
Alan
To reply to this message, follow the link below:
http://www.facebook.com/n/?inbox/readmessage.php&t=144622572318&mid=12f3258G27d96182G2c9a559G0
___
This message was intended for sgreen@opaltelecom.co.uk. Want to control which emails you receive from Facebook? Go to:
http://www.facebook.com/editaccount.php?notifications=1&mid=12f3258G27d96182G2c9a559G0
Facebook's offices are located at 1601 S. California Ave., Palo Alto, CA 94304.
« Last Edit: October 01, 2009, 09:20:55 pm by SamCB750A »
Offline Rod
« Reply #28 on: October 03, 2009, 07:28:31 am »
Basket for CR cluster
Offline Rod
« Reply #29 on: October 03, 2009, 07:29:21 am »
Offline Rod
« Reply #30 on: October 03, 2009, 07:30:04 am »
STD basket
Offline Rod
« Reply #31 on: October 03, 2009, 07:38:14 am »
STD basket, primary gear.
The 'special' basket has casting stamp FCC, the STD basket has Japanese ideographs. CR basket has ID that is 2-3mm wider than OEM, and different primary gearing. Any ideas guys?
Offline kayaker43
« Reply #32 on: October 03, 2009, 08:37:17 am »
Can you give us the primary drive gear tooth count so we can figure out the ratio? It may be an optical illusion, but the shaft bore size looks smaller?? Possibly a cb650 part? Does the inner clutch hub have coarse or fine splines?
« Reply #33 on: October 03, 2009, 08:46:50 am »
Thanks Rod. 78 teeth on the basket, 63 on the 550.
A CJ360 twin 5spd has 78 teeth also. Finding a primary drive gear to fit & with proper teeth count may be the hang-up here.
Offline kayaker43
« Reply #34 on: October 03, 2009, 10:01:46 am »
Very interesting.. The progression of primary drive ratios from 500/550/650 have always been to a lower numerical ratio. The crank gear is bigger, the clutch gear smaller.
500 - 3.246
550 - 3.063
650 - 2.740
This spins the clutch and trans faster, then the adjustment is made in the final drive. Since HP is torque x rpm, a faster spinning clutch and gearbox sees less torque, and torque is what bothers clutches. On the downside, there's more frictional losses in a faster spinning gearbox.
The clutch hub shown goes the wrong way with a higher (numerical) primary reduction which will send more torque through the clutch, presumably this is why it needs an extra plate? I suspect the different hub was neccessary to accomodate whatever main shaft was used for the CR box? We can only conclude that these must be borrowed parts instead of purpose built because they would never choose a higher ratio primary drive.
Unless,... they were going for less friction losses in the gearbox and weren't so worried about clutch slippage? Actually I like this thinking for a race bike. Why not use an old cb550 primary ratio and add thinner plates from a modern sportbike? Two opposing strategies, one goes for durability, the other for more efficiency.
Does anyone know the primary drive ratios, diameter and plate counts for a modern 600cc sportbike? It would be interesting to see which way evolution took us?
« Last Edit: October 03, 2009, 10:06:57 am by kayaker43 »
Offline kayaker43
« Reply #35 on: October 03, 2009, 10:19:54 am »
Just looked it up, a CBR600 has a 2.111 primary drive which falls in line with the trend toward faster spinning clutches and gearboxes. Then again, modern 600's do put out 100+Hp and the poor clutches need all the help they can get.
Now I'm convinced the Clutch hub (HRC?) shown must be from a cb360 or other model that the mainshaft was also borrowed from?
I posted some part numbers in another thread but my Yosh 5 speed uses an inner hub from a CB350/360, but it worked fine with the stock 550 basket. The part number was 22120-312-010 It also used a matching coarse spline mainshaft but it wasn't in a parts bag and I don't know the tooth count. I purchase the gearbox from someone and some of the items were removed from their bags.
« Reply #36 on: October 03, 2009, 10:49:55 am »
When we can find that primary drive gear tooth count, it may shed a light on your thinking.
The CB360 mainshaft is too long to drop straight into a 500/550 but with some work I believe it is do-able. A little magic is needed to use the 550 clutch on the 360 shaft, but also do-able.
1st gear on the 360 MS is 16T & the CS mate 40 for a 2.5:1 ratio.... quite short, so they must have have used a different combination because as several of you have mentioned 1st was geared tall and hard to launch.
Offline kayaker43
« Reply #37 on: October 03, 2009, 05:35:24 pm »
I finally uncrated my old race motor and split the cases. I posted the Yosh CR 5 speed ratios in the original CR gearbox thread
http://forums.sohc4.net/index.php?topic=52012.msg645077#msg645077
It seems like that thread should also be moved to the "high performance" forum??
« Last Edit: October 03, 2009, 09:46:11 pm by kayaker43 »
Offline Bill/BentON Racing
    • BentON Racing
« Reply #38 on: October 04, 2009, 05:24:20 pm »
Yeah,great info,please move to Hi/Po section.Bill
BentON Racing Website
BentON Racing Facebook
  • Moderator
« Reply #39 on: October 05, 2009, 08:36:02 pm »
could be great to learn some details about that 500/600 sohc and see pics
was it an official Honda Britain effort?
now the whole mystery as why Pops called it an IOM cam starts to unfold
TG
TG, there were pics of all three of Alan Jacksons winning bikes in my book. The bike was not factory as far as I know.
It belonged to a dealer in Preston, Lancashire named Bill Head. Apart from Bill Smith Motors, Bill Head was one of the first shops to race Hondas.
It wasn't the first big blood for the CB500 though, Billy Smith took one to victory in the 500cc Production TT a few years Earlier, I have a nice picture of that as well.
Sam. ;)
Offline turboguzzi
« Reply #40 on: October 06, 2009, 03:02:54 am »
TG
Sam. ;)
Do you have scanners there in the UK?  ;)
  • Moderator
« Reply #41 on: October 06, 2009, 11:32:55 am »
I don't but I know someone who dose, problem is, pictures are in a book. ???
Sam. ;)
    • BentON Racing
« Reply #42 on: October 07, 2009, 05:23:19 pm »
What?? No excuses young man,we want to see,put Ben to work! ;D ;D ;D,Bill
  • Moderator
« Reply #43 on: October 07, 2009, 05:35:57 pm »
Yes Billy, It's Ben who has the scanner, I'll have to cut pages out of the book. :( :( :(
Sam. ;)
Offline turboguzzi
« Reply #44 on: October 07, 2009, 11:28:54 pm »
Sam. ;)
Sam
dont know what kind of weird scanners you brits use, but there's another exotic possibility:
the digital camera!
hope you heard about it, just palce it in front of said book, press the shutter and hey presto, you'll get a fine picture!
Interesting no? What say U?
Offline voxonda
« Reply #45 on: October 07, 2009, 11:41:12 pm »
TG
Sam. ;)
Wasn't the bike of Bill Smith the Yoshimura/Dixon build 500?
Rob.
« Reply #46 on: October 08, 2009, 10:18:59 am »
Is this by chance the bike? This is from a very old Yoshimura catalogue.
Edit, taking another shot at improving pic quality.
« Last Edit: October 08, 2009, 08:31:55 pm by bwaller »
Offline voxonda
« Reply #47 on: October 08, 2009, 11:20:22 am »
That is the bike I mean, btw. got the same cataloque.
Offline turboguzzi
« Reply #48 on: October 08, 2009, 11:41:23 am »
That's really neat!
Brent, if your scanning SW has something like a de-screen option then use it.....
Guess that's not the Bill head Honda in any case, Dale Alexander was the guy who brought Yoshimura to the US (and father of ex motorcycle.com editor sean alexander).
http://www.motorcycle.com/news/news1867.html
Still, that huge drum is pretty amazing, guess it was tons better than the early single disc.
Cant really see if the frame is stock or not, there seems to be an horizontal tube running behind the pipes
Bravo!
TG
Offline voxonda
« Reply #49 on: October 08, 2009, 12:52:45 pm »
That is not a drum but a magnesium conical hub with a disc inside and lockheed caliper.
Have no scanner on hand but on page 67 of this beautiful cataloque it is said that Bill Smith took first place on it on the Isle of Man.
Tomorrow will scan that page, has a marvelous picture of that 500 engine on it.
Rob
