Author Topic: Yes, I used a pressure washer...  (Read 2887 times)
Offline ev0lve
« on: July 27, 2009, 09:03:36 AM »
Well, Saturday I decided to wash the bike. Took it to the local car wash and pressure washed the wheels which worked great but my enthusiasm got the best of me and I took it to the engine as well. Thought I just did the front and sides and any water would just dry up but today I still have this problem:
It bogs off idle and when getting in the throttle on the highway. Previous to my being stupid it was fine.
So, what should I be looking for first? Points? Spark plugs? Plug wires? Coils? Carbs?
It's had two days to dry out in 80+ weather so I'm a little stumped. Looks pretty though  ::)
Offline azuredesign
  • Knupping pin
Re: Yes, I used a pressure washer...
« Reply #1 on: July 27, 2009, 09:20:57 AM »
I'm assuming you've run it for enough miles so that any water in the carb bowls has drained, but what if the air filter got wet and you're sucking it in from the element?
« Reply #2 on: July 27, 2009, 09:23:15 AM »
Look under your point cover or anyplace the  moisture can recondense.
Offline ev0lve
« Reply #3 on: July 27, 2009, 09:23:51 AM »
Hmmm, about 20 miles so far. In either of those scenarios the problem clears/drys up by itself, eventually?
Offline ev0lve
« Reply #4 on: July 27, 2009, 09:25:07 AM »
Can do a little later today.
Offline robe0531
« Reply #5 on: July 27, 2009, 09:33:59 AM »
i would say water in points cover not 100 percent sure
1978 cb750k
1968 Honda ca160
« Reply #6 on: July 27, 2009, 09:36:25 AM »
Yes, do check under the points cover.
Also check to see if your air filter got wet.  If paper, water can collapse the fibers causing higher restriction.  This would also show as soot deposits on your spark plugs.
Also, pressure washers force water/phosphate into electrical connections.  That won't cause immediate issues, but it will speed up the corrosion process on them.
At least check the main frame ground lug connection.  Remove, wire brush, grease and reinstall.  Easier to do in your garage, rather than out on the road somewhere.
« Reply #7 on: July 27, 2009, 09:53:09 AM »
See IGGY, a few momnets saved can cost you hours down the road. If you have moisture under the points cover a haridrier can clear it out. Do the points and the cover both.
Offline ev0lve
« Reply #8 on: July 27, 2009, 10:30:05 AM »
I know, I know. I knew better even but... it was blowing all the crap away which was deeply satisfying in a short term kind of way  ;D
Think I'll grab a screw driver and take the points cover off now so it can dry up in our 90+ degree day around here.
Didn't put it to the filter or the top of the engine directly and didn't remove the side covers. Did hit the lower part of the engine pretty well though. Main frame ground lug is at the motor mount bolt, yes?
Offline 736cc
« Reply #9 on: July 27, 2009, 10:36:48 AM »
Dry coils and plug caps and wires. Clean or change your plugs, if fouled they don't clean themselves.
Offline michrobi
  • Goldenrod blew a 5" hole out the front with a
  • On a neverending quest for more garage space
« Reply #10 on: July 27, 2009, 11:30:50 AM »
Water will sit on top of gas, so it might be wise to drain your float bowls.
-Mike
'78 CB750F All stock except for the powerplant. Jived it off my Dad in the spring of '94. He had it since 1980 and it's the first bike I ever rode on.
Current project: http://forums.sohc4.net/index.php?topic=67756
How's them SOHC4 patches coming?
Offline ev0lve
« Reply #11 on: July 27, 2009, 11:47:09 AM »
Will it? I thought it'd sink (which is why I had all those pinhole leaks in my original tank).
Specific gravity Imperial Units
Gasoline   42.5
Water   62.4
Still, might explain the bogging when in the throttle.
« Last Edit: July 27, 2009, 11:49:10 AM by Iggy »
Offline michrobi
« Reply #12 on: July 27, 2009, 12:07:07 PM »
Just based on experience. I wash my bike at the car wash often, but I wrap my carb pods in plastic shopping bags and keep the water away from the handlebars. Everything else gets direct wash from the power washer with the covers left on the bike. The first time I washed it I didn't bag the pods and it wouldn't stay running. I drained the bowls and it was good.   :)
-Mike
Offline Gordon
  • 750K1, 550K2
« Reply #13 on: July 27, 2009, 12:14:00 PM »
Gasoline   42.5
Water   62.4
You're correct.  The water sinks to the bottom.
« Reply #14 on: July 27, 2009, 02:00:19 PM »
If you have a 750 air box, the inlet is at the bottom, just above the engine case.
Offline ev0lve
« Reply #15 on: July 27, 2009, 02:03:55 PM »
And my recollection was the slit being at the top. Damn. Sometimes I just want to do the George Costanza thing and whatever my natural inclination is just do the opposite  :D The trick is knowing when...
Offline razor02097
  • Not a fool, just an
  • Yes its a Honda You got an F'in problem with that?
« Reply #16 on: July 27, 2009, 02:51:32 PM »
These things where built to withstand rain... not 15,000 PSI of water madness  ;)
seriously though I would have voted for water in airbox too.
Project Rina
That is an inconceivably egregious transgression against my rudimentary concordance of socially shunned individuals.
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
« Reply #17 on: July 27, 2009, 06:44:05 PM »
+1 - happens to me every time I clean the bike, even when just using a garden hose. Trying to just 'drive it out' ended up in frustration even after a dozen miles. Drain the float bowls into a small glass or bowl and you will actually see the water beads (it doesn't mix with the gas). While the screw was out and bowl drained, I actually shot in some fresh gas with a syringe and that blew out a last bit of water and general crap out of there.
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
« Reply #18 on: July 27, 2009, 06:57:21 PM »
Whats done is done. Dry everything out and make it a lesson learned. I do my back wheel with a pressure washer to get the chain lube off. I also glued the rim strips in with silicone to keep water from getting inside the rims.
Offline ev0lve
« Reply #19 on: July 27, 2009, 08:29:14 PM »
Hmmm, drained the float bowls and dryed out the points. No love. Guess it's on to the filter.
Offline MoTo-BunnY
« Reply #20 on: July 27, 2009, 11:59:36 PM »
I'm really surprised the float bowls weren't it - the symptoms you described were identical to what I had.  ???
One other thing I found that was an issue after like the second time I washed my bike I think, was the spark plug wire ends (believe it or not). I checked all the usual suspects first and was still having bad running issues, with one cylinder not even firing (and cool to the touch). I was really baffled until I took off a spark plug cap (off of the end of the wire) and found the center wire a nasty green corroded mess. I'm sure it was corroded before I washed it but I think some moisture got up there and finally pushed it over the edge to not making the connection anymore. I cut about 1cm or so off the end of each wire, put in some dielectric grease into the cap and on to the little screw that goes back into the wire. Problem was not only solved but I have driven repeatedly in some of Oregon's worst rain storms since with NO problem (along with my home made neoprene points cover gasket. . he he)
1973 Honda CB500K2
Offline ev0lve
« Reply #21 on: July 28, 2009, 06:56:41 AM »
Well, I was planning on changing the oil/plugs/putting some brake squeal in the calipers/tuning it up and syncing the carbs this weekend. Spose I could just take it ALL apart  ;D
Who knows, maybe it'll have fixed itself this morning  :P
Thanks everyone for the help! Much appreciated! I'll post back whatever happens.
