Author Topic: Opps, I think I toasted something.  (Read 1982 times)
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« on: July 26, 2009, 06:50:22 PM »
Well, finally rested enough to go look at Surely after the long ride and to find out why she was acting up on the way home.  She started right up no problems there, but when I gave her a quick twist, black smoke come out the exhaust for 2/3.  She has a 4 into 2, 1/4 and 2/3.  I am kind of hoping it is just an exhaust valve seal leaking, but don't want to open her up until the Goldwing is back together.
Can I cry now? :'(
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Offline honda750k
Re: Opps, I think I toasted something.
« Reply #1 on: July 26, 2009, 08:18:50 PM »
black smoke is fuel.  sounds like your problem is a fuel one.   much simpler and nowhere near as expesive.
if it were oil, the smoke would have an oily smell, and be greyish blue. so I highly doubt you've got a valve seal issue.
These bikes dont die, they hibernate until the right person wakes them up again.
Offline clarkjh
  • Expert? If only.
« Reply #2 on: July 27, 2009, 02:51:42 AM »
I hope that's true.  I'm wondering if a bad cap could be causing the problem.  She has started to hate running in the rain.
James
SOHC/4 #3328
Offline razor02097
  • Not a fool, just an
  • Yes its a Honda You got an F'in problem with that?
« Reply #3 on: July 27, 2009, 02:39:31 PM »
cracked coil will also cause rough running in rain.
Any bad sounds?
Remember that spark plugs are a window to whats up inside the cylinder.
Project Rina
That is an inconceivably egregious transgression against my rudimentary concordance of socially shunned individuals.
Offline clarkjh
  • Expert? If only.
« Reply #4 on: July 27, 2009, 02:59:54 PM »
It can't be a coil or it wouldn't be the two inside cylinders.
Any bad sounds?
Back firing from the exhaust
I know, just hate having to pull the two inside plugs.
Once I get the wing back together and out of the carport then I will have semi dry room to work on Surely.
James
PS:  left the petcock "ON" over night and noticed a rainbow under her today, me thinks I have a float sticking.
SOHC/4 #3328
Offline razor02097
« Reply #5 on: July 27, 2009, 03:04:22 PM »
is 2 and 3 not going to the same coil?
Project Rina
Offline clarkjh
  • Expert? If only.
« Reply #6 on: July 27, 2009, 05:13:42 PM »
Nope, coils fire 1/3 and 2/4 if I remember right.
James
SOHC/4 #3328
Offline razor02097
« Reply #7 on: July 27, 2009, 06:41:28 PM »
James
hmm... my bike has one coil fire 1/4 and the other fire 2/3...   the firing order is 1,2,4,3 I thought.
« Last Edit: July 27, 2009, 06:56:04 PM by razor02097 »
Project Rina
Offline honda750k
« Reply #8 on: July 27, 2009, 06:51:41 PM »
Far as I know, unless your bike is unique or someone screwed up, one coil fires 1/4  and te other fires 2/3.
Offline clarkjh
  • Expert? If only.
« Reply #9 on: July 28, 2009, 06:55:56 AM »
Hmm. I'll have to go check it now.
James
SOHC/4 #3328
