Author Topic: Measuring float height  (Read 3853 times)
Offline mtr
« on: July 28, 2009, 12:08:03 PM »
I know this question has been asked before, but I can't find it.
When measuring float height, do you measure from the bottom of the float to the level where the bowl connects to the carb body? This was my assumption but I'm a complete carbtard. Seeing as how setting all the floats to 22mm on my 550F left me with fuel pouring out of the overflow hoses, I think I may be doing it wrong.
Also, another stupid question: with the carbs installed on the bike are the float needles inserted with the point or the spring facing downward?
The carb model is 069A if that matters at all.
Thanks.
77 550F / 80 750F
Offline Laminar
  • Retsam
Re: Measuring float height
« Reply #1 on: July 28, 2009, 12:20:05 PM »
Measure from the area of the carb body that the bowl gasket contacts to the lowest point of the float when the float is just touching the float valve spring. The float valve should have the pointed end inside of the float valve body, and the spring sticking out, touching the float's tang (touching tang? Sounds dirty).
Offline Laminar
  • Retsam
« Reply #2 on: July 28, 2009, 12:23:21 PM »
Offline mtr
« Reply #3 on: July 28, 2009, 12:26:03 PM »
The spring on the end of the float needle, right? Am I using the wrong terminology here? Again, I'm a self-confessed idiot.
If we are talking about the same spring, is there a point when the float tang shouldn't be in contact with the spring? My float valves (or needles) are always touching the tangs. They're just hanging loose inside the carb body, gravity pushes them in contact with the tang. This is with the carbs installed, I'm trying to avoid taking them out twice in one day if at all possible.
I wish that picture was more clear. Did that come from one of the shop manuals? I might be able to look it up.
So, the carbs in the picture seem to be on their side. It is possible to measure float height with the carbs installed, right?
« Last Edit: July 28, 2009, 12:28:52 PM by mtr »
77 550F / 80 750F
Offline Laminar
  • Retsam
« Reply #4 on: July 28, 2009, 12:34:50 PM »
You're correct (on the first point, I'll hold my thoughts on the last  ;D)
This is correct. You measure the float height at the point where the float has pushed the float valve into the float valve body and has just started to compress that spring
It is, but I found it posted on these forums.
It's possible, but it would be very cumbersome, especially trying to get to the middle two floats, since you have to be able to see the float valve to know when the float tang is compressing the spring.
Offline Laminar
  • Retsam
« Reply #5 on: July 28, 2009, 12:39:50 PM »
Here's a tool someone in another thread recommended making out of plexiglass or metal:
The U-shape goes around the float and touches the carb body. The bottom of the U pushes against the float. Put it on the carb, adjust float tang, re-check, etc. You could also make the U deeper and thread a screw vertically through the bottom of the U so that you can adjust your desired height.
Offline NickC
« Reply #6 on: July 28, 2009, 12:43:44 PM »
I made mine out of cardboard  :D
kedwards
« Reply #7 on: August 02, 2009, 12:56:37 AM »
Hi guys I used to own an italian 1975 500/4 k3 and i set the levels , by removing carbs off of the bike and tuning them upside down , then using the measurement in the haynes manual i set the float heights by bending the tangs , i set the pilot adjuster screws to the manual specs , put it all back on the bike started it up put the vaccum testers on adjusted the vacs , and for the three years i owned the bike it never missed a beat , a fantastic little bike that one. 8)
Offline Johnny5
    • CB350F build thread
« Reply #8 on: August 02, 2009, 04:51:47 AM »
Yep, I made mine out of an expired Chili's Restaurant gift card.  ;D
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline Johnie
« Reply #9 on: August 02, 2009, 04:59:13 AM »
Here is mine from a floopy...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
