Author Topic: High pitch noise or Howling from lower engine  (Read 1112 times)
76supersport750F
« on: July 29, 2009, 11:01:41 AM »
Hello  When riding at 5000 rpm and higher on the highway I hear a high pitch noise of howling from the lower engine clutch area.
Any one experience this? and what should I do or look for?
It goes away when I pull in the clutch lever.
Thanks
Offline 1timduke
  • '75 CB550
Re: High pitch noise or Howling from lower engine
« Reply #1 on: July 29, 2009, 04:50:07 PM »
Any recent oil changes?   Some types of oil are also bad for these wet clutches.   Does the noise accompany any performance issues like slipping?
-Tim
The only thing I miss about the South is Waffle House!
76supersport750F
« Reply #2 on: July 31, 2009, 07:26:19 PM »
The type of oil i put in when I got the bike was 10w40 Blend.   It was a really hot day when the noise happen.  I have change the oil to 20w50 and it seems better but I did not get the chance to get on the interstate and ride much.  There is still something there but not much at lower speeds.  I will ride it again on the interstate.  At lower speeds and on secondary roads it seem ok and not much a noise to bother me.
May be something is coming loose?  I am not sure.  May be it shows up when it is really hot?
I have only put 200 miles on it.    The bike has 16000 miles on it.
I will check back later and update.
Thanks
