SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
f2 engine case
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: f2 engine case (Read 1256 times)
eldar
Guest
f2 engine case
on:
November 23, 2005, 07:43:05 AM »
Looking to get an f2 engine case. Just the case no head or anything like that. Are there any oil feed differences or any other kind of differences between the f2 case and a K case?
I would like to get a case to clean up and paint and then use it for an 836.
Logged
scondon
No way my run was THAT slow, must be an
Old Timer
Mmmm......tasty bugs
Re: f2 engine case
Reply #1 on:
November 23, 2005, 08:32:55 AM »
The F2 case is the same as the others. Any differences in oil passages is above the base in the cylinder and head. Let me know if you have difficulty finding one as I have a spare(California).
Logged
MRieck
Really Old Timer ...
Big ideas....
Re: f2 engine case
Reply #2 on:
November 23, 2005, 08:33:09 AM »
The output shaft is different (much more stout) and uses a different bearing. The casting and bearing set ring groove is in a different place.That's about it.
Last Edit: November 23, 2005, 08:37:44 AM by MRieck
Logged
eldar
Guest
Re: f2 engine case
Reply #3 on:
November 23, 2005, 09:16:06 AM »
So if I were to swap all the parts, would everthing fit besides the output shaft?
Logged
MRieck
Big ideas....
Re: f2 engine case
Reply #4 on:
November 23, 2005, 03:36:53 PM »
It certainly should. I have used 78 transmission parts inthe earlier bikes with no problems.
Logged
dusterdude
Re: f2 engine case
Reply #5 on:
November 23, 2005, 06:05:52 PM »
hey eldar,f it!!!!
Logged
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
eldar
Guest
Re: f2 engine case
Reply #6 on:
November 24, 2005, 08:18:16 AM »
Well I got busy and forgot about bidding on the case. Oh well, they come up often enough. What i want to do is get parts for a second engine and use them to make my 836. That way, I always have a good engine if things go south doing the 836.
Logged
dusterdude
Re: f2 engine case
Reply #7 on:
November 25, 2005, 06:08:28 AM »
keep tryin man,you`ll get there one day.
Logged
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
f2 engine case
