Author Topic: maxi-dwell for a 750  (Read 1089 times)
Offline bucky katt
  • i am a pastafarian!
    • facebook
« on: August 01, 2009, 04:16:31 AM »
are these still made? i'm seriously thinking about making the dyna s go away.
Mark Twain - Notebook, 1894
jpswino
Re: maxi-dwell for a 750
« Reply #1 on: August 01, 2009, 07:16:31 AM »
My buddy just took his off and went back to dyna. What's the problem? I was able to see his Maxi run on the bike. Very cool by the way. Adjustments on the fly.
« Reply #2 on: August 01, 2009, 08:04:17 AM »
If you switch to a Maxi, be sure to check the straightness of the points shaft first. If it's not dead perfect, the timing for 2-3 will be very difficult to set correctly. The Maxi requires that you split the difference of points gap between the two sides to get the 2-3 timing, unles you get the last of their series, which had a sub-plate for the 2-3 side, pretty rare.  ;)
« Reply #3 on: August 01, 2009, 08:47:51 AM »
The Hun, changed his for Dyna.
 I am waiting to hear what great improvments he gained with the Dyna.
 I sre like the fixability of the Maxi...
