Author Topic: cb550 oil capacity  (Read 18764 times)
Offline delay pedal
cb550 oil capacity
« on: August 01, 2009, 03:13:34 PM »
74 cb550
clymers manual says 3.0-3.2 quarts of oil
i have 3 quarts in and the stick is dry
what gives?
i searched and checked the faq
Offline CBGhia
Re: cb550 oil capacity
« Reply #1 on: August 01, 2009, 03:51:39 PM »
should be 3.4 quarts.   3.2 liters.
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: August 01, 2009, 03:55:55 PM »
Just keep filling until it reads on the stick.
That is unless you forgot to replace the drain plug and there's a giant puddle of oil on the garage floor. ;)
Offline Bill/BentON Racing
    • BentON Racing
« Reply #3 on: August 01, 2009, 04:17:22 PM »
 Bike sitting level ? Bill
BentON Racing Website
BentON Racing Facebook
Offline delay pedal
« Reply #4 on: August 01, 2009, 05:04:57 PM »
thanks fellas it showed up at 3.4ish
another question, im using valvoline non-synthetic 10w40 motorcycle oil
ive adjusted the clutch cable to spec then adjusted the clutch adjustment on the cover.
at first the bike would lurch forward with the clutch in in first but not shift to N or 2 3 4 5.  After adjusting it, the bike wont lurch forward anymore, but it still wont shift.  Is the oil the culprit? If not Ill pull the cover and check the clutch.
    • BentON Racing
« Reply #5 on: August 01, 2009, 06:42:19 PM »
You should do it the other way around,put max free play in cable,adjust clutch at cover,then cable right above cover,then cable @ handlebar.Good Luck,Bill
