Author Topic: a question for someone more experienced than i am with welding  (Read 1398 times)
Offline bucky katt
  • i am a pastafarian!
    • facebook
i have a kerker header/megaphone on the k4 and i want to put a supertrapp on i was given last year. the question is, can i weld a stainless supertrapp to a mild steel header? and if so what welding wire do i use? this is with a mig welder and i have a 75/25 mixture in the bottle.
Mark Twain - Notebook, 1894
Offline razor02097
  • Not a fool, just an
  • Yes its a Honda You got an F'in problem with that?
Re: a question for someone more experienced than i am with welding
« Reply #1 on: August 03, 2009, 04:48:45 AM »
welding 2 metals is possible with a TIG but I would not recommend it.  I would sleeve the pipe and band clamp the muffler.
Project Rina
That is an inconceivably egregious transgression against my rudimentary concordance of socially shunned individuals.
« Reply #2 on: August 03, 2009, 05:39:10 AM »
You can weld it with either SS or mild wire Fuzzy, but I'd suggest you get some pure Argon, SS doesn't like mixes. Cheers, Terry. ;D
Offline bucky katt
    • facebook
« Reply #3 on: August 03, 2009, 06:00:03 AM »
thanks for that info Terry! now all i have to do is cut a small wedge out of the inside part of the curve at the end of the collector to tuck the end of the header in a bit so the supertrapp doesnt stick out like a broken thumb. that said.........does anyone here need a kerker/supertrapp megaphone that came with the cb750 exhaust?
Offline Jim F
  • go baby go
« Reply #4 on: August 03, 2009, 06:09:30 AM »
Call me if I can help if you decide to weld
www.jmfmicroweld.com
I have done this a few times on other peoples bikes as well as one or two of my bikes
and it worked well.
Jim
« Last Edit: August 03, 2009, 02:49:00 PM by big-jim »
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline NickC
« Reply #5 on: August 03, 2009, 06:09:59 AM »
Got any pics?
Offline IHWillys
« Reply #6 on: August 03, 2009, 08:08:38 AM »
I gas welded several stainless/mild steel joints using mild steel filler a few years ago on my E350's exhaust system.  They've held up just fine.  I wouldn't do this for something chassis/structural but it's exhaust so I just did it and with no apparent problems thus far.
Ken
Offline MJL
  • Don't listen to me, I'm no
« Reply #7 on: August 03, 2009, 11:30:55 AM »
Is that he complete exhaust, or just the muffler?
I cut up some glasspacks and welded them on, but the fiberglass fell out before I got the ends capped.
