Author Topic: Honda 360 question  (Read 1166 times)
Offline Johnie
Honda 360 question
« on: August 05, 2009, 10:01:17 AM »
Friend called...has a 74 Honda 360 that ran last year.  Says no spark.  Took off side points cover and he had oil there.  Am I correct like with the 750's there should be no oil under the points cover?  I have not had a chance to see the bike yet.  He said his coils have a honeycomb look to them like they boiled over...my guess is he needs new coils.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Gordon
  • 750K1, 550K2
Re: Honda 360 question
« Reply #1 on: August 05, 2009, 11:59:15 AM »
On the 360 the points are run off of the left side of the camshaft on the top of the engine, so he should definitely not have any oil in there.  I've never seen coils with a "honeycomb" look to them, but it doesn't sound good.
Offline Caminokid
« Reply #2 on: August 05, 2009, 12:49:34 PM »
No Honda that I know of has oil with the points. Find the leak and fix that first. Then go for the rest.
God created man...Winchester and a baseball bat made then equal. Evel Knievel
Offline 333
  • Time for change
« Reply #3 on: August 05, 2009, 01:35:08 PM »
Probably just an oil seal behind the advancer.  Easy fix.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Rampage1967
« Reply #4 on: August 05, 2009, 09:30:09 PM »
There is an oil seal & two rubber plugs behind that cover.
Check cam bore for play, if it is ok, then replace all three rubber parts.
No use changing the seal without changing the 30 year old plugs too.
Offline crazypj
  • I'm brill, me
« Reply #5 on: August 06, 2009, 12:53:40 PM »
if its only seal you got lucky.
 Usually though, seal leaks because cam bearings are worn.
 Need to pull cam cover and cam, to check
PJ
Offline Green550F
  • Nothing is as cool as that which you made.
« Reply #6 on: August 07, 2009, 07:21:45 PM »
Is he really in the points? Sounds like he pulled the alternator cover looking for points! ???
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
Offline Johnie
« Reply #7 on: August 07, 2009, 10:05:42 PM »
I think that is what he did too.  I can not get to see it until Sunday.  Will check it out then.  Thanks
Oshkosh, WI  USA
Offline Caminokid
« Reply #8 on: August 08, 2009, 03:52:19 PM »
I have coils for that bike. I just got a 360 with a locked up motor.
